Air source heat pum...
[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
70 Users
49 Reactions
21.7 K Views
 olly
(@olly)
Forum Handle: @olly
Manufacturer: Samsung
Model: HTQ AE140BXYDEG/EU
Type: ASHP,
Arrangement: Mono
Area of Country: Kent
Home Type: House (1960's house with 2023 single story extension)
Size: Square Metres: 232
Insulation Level: 6? Brick cavity with retrofit bead insulation for old part and 2023 reg standard for new part
Heat Loss Calculation: 14kW @ -1.7C (personally I think the calc is a bit high, but i'll have better data after the winter)
Type of Controller: Evohome with ASHP relay and underfloor
Type of Control: Weather Compensation for flow temp + room temperature thermostats
System Type: UFH for extension + K3 rads downstairs double rads upstairs
Total Output of Heat Emitters: ?kW
Buffer Tank or Low Loss Header: BT
Secondary Pumps: One for main circulation and one for UFH
Solar PV System: No
Power Diverter: No
Battery System: No
Nice and quiet heat pump. Going through planning was a bit frustrating
(@gillc)
New Member Member
Here goes.  I will do what I can!
Forum Handle: GillC
Manufacturer:Grant
Model: Aerona HPID17R32
Type: ASHP
Arrangement: ? I don’t understand the question!
Area of Country: West Coast of Scotland
Home Type: Detached House
Insulation Level: 8
Heat Loss Calculation: ?
Type of Controller: Hive thermostats - one upstairs, one downstairs. TRVs throughout.
Type of Control: Weather  compensation set by installer.  Hive.
System Type:  Radiators
Total Output of Heat Emitters: 18 kW
Buffer Tank or Low Loss Header: No
Secondary Pumps: No
Solar PV System: No
Power Diverter: No
Battery System: No
Sort Code 😂
Josephiah
(@josephiah)
Forum Handle: Josephiah
Manufacturer: Vaillant
Model: AroTherm Plus 12kW
Type: ASHP
Arrangement: Mono, High Temp, feeding space heating and 300l DHW tank
Area of Country: North of Scotland
Home Type: 5 bed detached, 2 floors
Size: Square Metres: ~230
Insulation Level: Hmm... 6/10? 15 year old build, so not bad, but no eco-house. EPC claimed 200mm in loft, but untrue, so will be adding another 200mm to its current 150ish in due course.
Heat Loss Calculation: 10.6kW @ Amb. Temp, of: -4.4°C
Type of Controller: Modulating, Thermostat in each zone, TRV's
Type of Control: Weather Compensation, twin zone (upper/lower floors)
System Type: New radiators throughout, sized for system. New 28mm pipe runs from ASHP to zone manifold, existing 22mm distribution and 15mm radiator piping reused.
Total Output of Heat Emitters: 12.3kW
Buffer Tank or Low Loss Header: 45l buffer tank
Secondary Pumps: One circulation pump
Solar PV System: (6.5kWp due soon, awaiting DNO permission)
Power Diverter: No
Battery System: (9.5kWh GivEnergy due soon, to be installed with PV)
(@squarepeg77)
Forum Handle: squarepeg77
Manufacturer:Daikin
Model:Altherma 3 EDLA09DA3V3
Type: ASHP
Arrangement: Mono
Area of Country: Hertfordshire
Home Type: Detached house
Size: Square Metres: 135m2
Insulation Level: 6? 1960s, cavity wall insulation and loft insulation
Heat Loss Calculation: 6.6kW @ -2C
Type of Controller: Daikin Madoka
Total Output of Heat Emitters: 7.4kW
Buffer Tank or Low Loss Header: Buffer tank (I think)
Secondary Pumps: No
Solar PV System: 4kW
Power Diverter: Eddi
Battery System: No
@squarepeg77
Welcome to the forum.
The value given for 'Total Output of Heat Emitters: 7.4kW' seems rather low. Is this at the standard 50C Delta T?
(@squarepeg77)
@derek-m 7.4kW is the sum of the “output at design temperature” figure from my radiator schedule.
Posted by: @squarepeg77
The standard way of denoting the thermal energy output capacity of radiators is at a Delta T of 50C.
(@squarepeg77)
Ah, sorry. I don't have that figure to hand.
Although from memory I think the output at Delta T of 50C is a bit less than 2x at our design temp of 50C max flow.
(@hughf)
An update on my system:
Forum Handle: hughf
Manufacturer: Cool Energy
Model: CE-iVT-9 (9kW, r410a gas)
Type: ASHP
Arrangement: Mono
Area of Country: Somerset
Home Type: End terrace
Size: Square Metres: 114m2
Insulation Level: 50mm cavity, filled. 300mm loft, Triple glazed
Heat Loss Calculation: 6.7kW @ -4C
Type of Controller: Cool Energy supplied
Type of Control: Weather compensation (no thermostat)
System Type: Radiators + UFH + Fan coils
Total Output of Heat Emitters: 6.8kW @ dT25
Buffer Tank or Low Loss Header: Neither
Secondary Pumps: No
Solar PV System: No
Power Diverter: No
Battery System: No
Im in the process of updating the heat pump roll call. Can you please visit the first post of this topic and see if you and your heat are on it. If not, please simply leave a reply with your heat pump size, model and brand. You don’t have to the extensive detail if you don’t want to.
bontwoody
(@bontwoody)
Here is mine, Mars
Model: Gen 6 5kW
Type: ASHP
Arrangement: Monobloc
Area of Country: Pembs
Home Type: Detached bungalow
Size: Square Metres: 100m2
Insulation Level: Maybe 6/10 - Stone original build with filled cavity extentions
Heat Loss Calculation: DIY install, ran gas combi at 45C during winter to identify upgrades
Type of Controller: Samsung controller in hall
Secondary Pumps: No
Solar PV System: 6.9 kW
Power Diverter: Yes, but not used at present as cheaper to heat DHW at night and export
Battery System: 5 kWh Huwaei Luna
tworivers
(@tworivers)
Manufacturer: Domusa
Model: DC16 16 KW power output 11Kw
Type: ASHP
Area of Country: Yorkshire Dales
Home Type: Old Farm House
Size: Square Metres: 200
Insulation Level: Internal 50mm kingspan with air gap downstairs 25-50 Polystyrene upstairs
Heat Loss Calculation: W/m2 10.89
Type of Controller: 1 room controller
Type of Control:
System Type: UFH.and radiators
Total Output of Heat Emitters: kW UNKNOWN
Buffer Tank or Low Loss Header: yes
Secondary Pumps: UNKNOWN
Solar PV System: No
Power Diverter: UNKNOWN
Battery System: No
Interests DIY & motorcycle travel
Page 4 / 9
