Dodgy Vaillant ASHP foundation & Eddi Diverter Making Central Heating Water Dirty
@jennyross I like your descriptions, they're helpful. Sounds like metal deposits to me. It's not uncommon to find some in most systems tbh. Are you finding that this is causing any issues like high running costs, or perhaps flow faults that stop your heat pump running? Or was it mainly the engineer telling you that it was a problem?
You might consider asking the next maintenance engineer to run through the process of cleaning the filters with you so you can potentially do it yourself another time.
Planning your dream house? Book a simple one-to-one consultation to get you on a good path - here.
@sune thank you. I’ll labour on with layperson’s descriptions then 😅
I don’t think the running costs have been higher in recent months. The installer showed me the HW tank filter blocked with ferrous (thanks toodles) material which he said was a problem.
if this is likely to be the result if the filters haven’t been cleaned or replaced at service, then maybe it’s built up over the last year?
@jennyross a totally blocked filter will stop the heat pump from working (it would give a "flow fault") so I guess that wasn't happening. And it's good that it was doing its job and protecting some of the narrow water pathways in the heat pump from that crud which is why its there. You would likely expect some dirt there, as you would with most types of filter really.
If it was my system I'd be tempted to have a look at the filter again in a few weeks, check how much it had caught (and give it a clean), then use that to get some sort of idea of how much rubbish is in the system and whether additional action is a good idea.....or not. Checking and cleaning a filter isn't a highly technical job nor is it specific just to heat pump systems - really any heating engineer should be able to do that, or indeed a competent homeowner as long as they know the simple steps required.
I wouldn't expect much more detritus to build up in the summer as you'll probably have the heating off - so the heat pump only has a very short and simple pipe run to and from your water cylinder - there shouldn't be a significant source of detritus there.
When you turn on the heating though then the rads are part of that water circuit - and that's probably where it came from/is coming from. So perhaps also a good idea to check that filter once the heating has been on for a couple of weeks later in the year. It might well also be that you have not much of a problem at all!
- 2,338 Topics
- 52.8 K Posts
- 478 Online
- 5,994 Members
HistoryFeb 25 - 9.5Kw 20 panel South Facing Solar Array...
By SteveT , 2 hours ago
RE: What a Bad Heat Pump Installation Looks Like
@cathoderay There is always the 7.62 1in5 link of socia...
By Grantmethestrength , 2 hours ago
Now the proud owner of: 4.1Kw peak Aiko Neostar solar...
By TechnoGeek , 5 hours ago
I did, thanks, and thanks to for reminding me I should ...
By cathodeRay , 6 hours ago
RE: Latest NIBE model has known defect and no solution
@kings I don’t I’m afraid as I submitted it through my ...
By richardpool , 7 hours ago
Aira called me back today, but not sure we got to the a...
By ChandyKris , 11 hours ago
RE: Replacing my 18 month old Hitachi Yutaki ASHP
That level of cycling is normal and absolutely nothing ...
By JamesPa , 16 hours ago
@hcas Hello Henri. It is disappointing, but I must pres...
By DavidAlgarve , 1 day ago
RE: Experience with Mitsu Par 50/60 Wireless Controller
The 27°C request doesn't boost the weather compensation...
Oh and it was installed by Stevie Wonder!
There seems to be plenty of evidence to support this. ...
RE: One Year Review: Grant 13kW ASHP - A Catalogue of Errors
@solenoid it sounds like you are making progress. No n...
RE: How good is the app support for your heat pump?
I think you are right about the ebus stick. It's cert...
RE: My DIY Heat Pump installation
@majordennisbloodnok Element-ary my Dear Major.
Welcome to the forums @isaac. What you’re describing is...
Win an Eve Smart Home Bundle worth over £350!
Win an Eve Smart Home Bundle worth over £350! ...
