6 Red Flags to Avoi...
6 Red Flags to Avoid When Considering a Heat Pump Installation
14 Users
31 Reactions
@jamespa it is a good idea, but not easy as you say. We actually have something along these lines scheduled in for recording next week Friday for the podcast.
(@Clover Rayner)
This article highlights important factors to consider when installing a heat pump. Identifying red flags, such as poor sizing, improper installation, and lack of maintenance plans, ensures you avoid costly mistakes and achieve optimal system performance.
This post was modified 9 months ago by Mars
(@nogotony)
New Member Member
Posted by: @gt22
If I had a new ASHP installed I would still have to have a hot water cylinder. I watched the relevant video on this site. But I don't need any buffer unit.
Can I get clarification on this point.
Can the ASHP External unit, supply heat for Central Heating radiators or UFH at one temperature and one set of F&R pipes and do that supply directly? Bypassing the cylinder?
Or have I got that completely wrong and need to go away and do some serious reading? 🤔
This post was modified 9 months ago by Mike@MH
Posted by: @nogotony
Posted by: @gt22
The ASHP, just like a boiler, can supply water at only one temperature at any time.  So it switches between space heating and DHW.  There will be one set of F&R from the heat pump, which splits into two sets at a diverter valve.
The reason that boilers (as we set them up in the UK) can do both simultaneously is that they run the heating at a high flow temperature, resulting in both reduced comfort and a 10% increase in energy consumption and therefore cost.  Boilers, like heat pumps, are actually best run at a low temperature with weather compensation (best both for comfort and cost!), but in the UK we rarely do this, unlike some more enlightened countries in mainland Europe.
(@alfapat)
Read your Red Flags with interest. Presently tweaking my system and getting the flow temperatures down as for the past 8 yrs It has been set at 50c
Currently adjusted lockshield valves to balance the Rads and brought the flow temps down to 44c without realising musch difference . I notice you suggest 38c which is quite low to what I have had it set but willing to try.
Can I ask what flow speed can my system run at , I notice there is a graduated glass viewing setting.
I also have a buffer tank in the system which I have only discovered from this forum may not be needed . However its there and reluctant to change , due to cost.
Page 4 / 4
