Bank holiday joke. A heat pump engineer walks into a bar...
@editor Another heating engineer walks into another pub … ‘Pint of your best beer landlord and make it very cold’ Landlord: ‘Sorry Mate, I’m fresh out of glycol.’
After days of arguing with a heat-pump installer, the customer is sick and tired of a system which still doesn't seem to be working.
That evening he's dreading the next day when everything was meant to have been completed. He picks up a discarded pressure valve from the floor beside the third buffer tank and casually rubs his fingers across the brass stem while he considers whether to throw it at the heat pump or the installer.
To his surprise, a blue genie appears from the end of the pipe and grants him three wishes.
Delighted, the man has no trouble in saying what he wants.
"I'd like to have this heat-pump installation completed and properly commissioned to operate using as little energy as possible. I want a full set of drawings with user instructions specific to this house, and finally, I'd like certificates of compliance with Part-L and Part-P of the Building Regulations," he announces.
"Phew!" exclaims the genie. "That's more like a miracle than a set of three wishes. But let's see what I can do. Your wishes are my command."
In a flash the pipe insulation is properly fitted and sealed, TRVs removed from radiators and lockshield valves balanced. The controller gets configured with the required weather compensation settings, temperature sensors repositioned where they should have been, and the pumps quietly hum as they achieve the optimal flow temperature.
The genie hands him the system schematic, user instructions and two Building Regs certificates.
"That was amazing," says the customer. "I had begun to think that this wouldn't ever be possible."
"Me too!" replies the genie, who smiles and quickly disappears.
The next morning, the installer arrives to find everything completed and working.
"How did you manage all this overnight?" he asks.
The customer tells him about the genie and the three wishes, whilst the installer gasps with amazement.
He reaches into his bag, pulls out a notepad, scribbles out a few items on the list and hands over the top page to the customer.
"Here's the bill," he announces. "Prompt payment would be appreciated."
The customer looks through it and remarks that it's a lot higher than the original quotation.
"Ah yes," explains the installer. "I've had to strike out the government's £7500 subsidy, and then add in a chargeable warranty and maintenance contract. Genies aren't allowed to be MCS registered."
"Whyever not?" enquired the customer.
"Coz they don't do any proper customer service. They're just here today and gone tomorrow!"
Turn up your volume and listen to Heat Pump Euphoria
Do we assume @editor that Heat Pump Euphoria is to be your submission to DESNZ on Delivering a Smart & Secure Electricity System?
It seems to be missing a verse on Regulatory Controls to implement Cyber Security.
@transparent I am eager to see the royalties start rolling in for my heat pump’s appearance fee! 😉 Toodles.
@toodles well noticed 🤣
Following the second crusade, Saladin summoned his War Lords to Court, prepared to lay siege to Jerusalem.
Alas, one General arrived late with his warriors, and Saladin demanded to know why.
"A thousand apologies, Your Excellency. I did not receive your message. My page exploded".
Saladin glowered at him, then beckoned that his scribe approach the dais.
"Can his account be verified?"
The scribe bowed low. "At your command, Your Excellency."
He hurried behind a red velvet curtain.
The awkward silence was broken only by a series of taps and clicks.
A minute later the scribe returned.
"Well?" inquired Saladin.
"Your Excellency, the War Lord tells the truth. I have searched the records of the known world, and they do say 'Error 404 - Page not found.'"
In breaking news, police have discovered a suitcase containing a man's torso in a location north of Bury Head.
This comes just a month after a member of the public found a briefcase with a head in it less than a mile away.
Police asked the media not to speculate, and said they were investigating the incidents as separate cases.
In a news update, a Police Spokesman has refused to be drawn on a cause of death.
He said detectives were working on the assumption that the head and torso are unconnected.
- 2,118 Topics
- 46.5 K Posts
- 19 Online
- 4,522 Members
@majordennisbloodnok Thank you. I have sent a very ster...
By El3b , 33 minutes ago
Fitting new shower valve ..........
This may be too generic but I need to change the ...
By Lenny , 2 hours ago
So the manual is correct and looks fine to me, to abbre...
By ASHP-BOBBA , 6 hours ago
Hi I, like others, avoid Amazon for ethical reasons....
By Topher , 7 hours ago
By Transparent , 7 hours ago
By normpang , 8 hours ago
By ASHP-BOBBA , 23 hours ago
By Toodles , 1 day ago
By Old_Scientist , 1 day ago
By Burtis , 5 days ago
By JamesPa , 5 days ago
By Old_Scientist , 5 days ago
By Lucia , 6 days ago
By Ashfp , 6 days ago
By Mars , 1 week ago
