Has Anyone Else Noticed a Decline in Tradesmanship?
@cathoderay Hence my rider about ‘all else being equal’, but, of course, it is difficult to know what the ‘equal’ is! ☹️ Toodles.
- 2,342 Topics
- 53 K Posts
- 547 Online
- 6,000 Members
RE: MELcloud scheduling misbehaviour
@downfield I wonder if it is the MELCloud app that is t...
By DavidAlgarve , 10 minutes ago
RE: Poll for Time of Use, tariffs, technology
@jamespa If you have no nett export then don’t do IO...
By Papahuhu , 27 minutes ago
I've been thinking of emailing Homely to ask for a few ...
By JohnnyB , 58 minutes ago
Max output of Heat pump (Daikin 4Kw EDLA04)
Hello, I am a bit puzzled that according to pcdb tes...
By GeorgeA , 1 hour ago
In that case, @technogeek, I’d sign up for the free sol...
RE: Has Anyone Else Noticed a Decline in Tradesmanship?
@cathoderay Hence my rider about ‘all else being equal’...
By Toodles , 3 hours ago
RE: Heat Pump Performance Analysis Web App using Modbus Data
@redzer_irl — all my heat pump data is in csv files, me...
By cathodeRay , 3 hours ago
That’s not a problem. If you can hit the main landing p...
By Majordennisbloodnok , 3 hours ago
RE: Configuration issues with 10kW Midea R32 heat pump
@benson I believe there are quite a few of these instal...
RE: 10kw heat pump run in 24*7 data?
I would say you most likely do need 10kW. My gas consu...
By JamesPa , 4 hours ago
RE: Here is my heat pump installation with questionable COP in Italy
Well in Italy there is nothing controlling the quality ...
By materox345 , 6 hours ago
RE: What a Bad Heat Pump Installation Looks Like
@editor The trick to an inside unit installation is to ...
By MikeFl , 20 hours ago
RE: Different dT on each radiator?
The way heating systems are designed will result in rou...
By JamesPa , 23 hours ago
PS by visually merging the two tables as above, I ended...
By cathodeRay , 1 day ago
RE: Homely for Daikin Altherma 3 - Petersfield Area
@russ If you would care to pose your questions on one o...
By Toodles , 1 day ago
@cathoderay the guy I spoke to on the phone seemed very...
By Burtis , 2 days ago
RE: British Gas vs Octopus Energy vs Heat Geek vs EDF vs Aira vs OVO vs EON.Next vs Boxt
I get the impression that that comment "they don't comm...
@majordennisbloodnok Just in case there are variations ...
RE: Latest NIBE model has known defect and no solution
@kings I’m glad I could help. NIBE are taking this very...
