Battery max dischar...
Battery max discharge rate
3 Users
2 Reactions
(@pauldavies83)
Currently looking at home storage batteries to reduce the incoming electricity unit rate shock, and had a (perhaps silly) question
If the max discharge rate of a battery is (for example) 3kWh, and my house is requiring more than the battery can supply (e.g. using the electric oven + hob), does the grid supply the remaining demand and the battery supply as much as it can, or does the battery supply nothing and the grid everything in this instance?
Our usage pattern shows most of our daily demand is when we cook dinner for the kids, which obviously we can't realistically time-shift, so the battery would hopefully do this for us (to a certain extent).
Cheers
(@majordennisbloodnok)
I can only speak for my situation, but I'd hope it's fairly typical.
My array and battery have been configured with a kind of hierarchy.
  1. If the sun is shining, the PV array will generate.
  2. If there is an electrical load, the electricity generated will try to meeting that demand.
  3. If we're generating more than we're consuming, it'll pile the rest into the battery.
  4. If we're generating more than we're consuming and the battery is full, it'll export the excess to the grid and we'll be paid as a result of our outgoing tariff.
  5. If we're consuming more than we're generating, the battery will try to meet that demand until it gets down to 10% (in order to protect the battery).
  6. If we're consuming more than we're generating and the battery is down to 10%, the excess load will be met by energy from the grid.
  7. Over night, during the cheap rate period, the battery will be trickle charged back to about 75% from the grid ready for the big hit from the air source heat pump in the early morning before we're generating again.
My understanding, although I haven't tried tinkering, is that all these scenarios can be configured, so the heirarchy isn't set in stone.
Does that help?
(@batalto)
@pauldavies83 the battery will supply whatever it can, then the grid picks up the rest. for example,
4kw demand = 1kw from grid and 3kw from the battery (until the battery runs out)
262m2 house in Hampshire
(@pauldavies83)
Thanks both for confirming what I'd hoped!
Our day usage is actually quite small, so I think we could get most of our usage covered by the battery and shift as much other usage as possible to off-peak. There would just be the odd time when we used too many things at once where we would need to import during the peak.
