48 Users
333 Reactions
102.9 K Views
Matthew_W
(@matthew_w)
Posted by: @editor
I’d be interested to hear the feedback and consensus on the tariffs we discussed recently and if you agree:
I watched a couple of days ago and have to agree with @jamespa that it didn't necessarily bring any clear answers.  In particular there seemed to be a head on disagreement between one person who said it was madness to run a heat pump without batteries and someone else who doubted if buying a battery to grid charge made sense, pointing out the 7p overnight tariffs are loss leaders and can't last forever.
I am still pre-heatpump and i must say the tariffs question is daunting.  Some calculation needed to work out the costs.  I want to do the right thing in terms of CO2 emissions but not at any cost...
I have an EV and am on Octopus Intelligent Go at the moment.  Where would I go if I got a heatpump?  Last years consumption, about 15500 kWh of gas, about 5250 kWh of electricity, of which about 2700 kWh went to charge the car.  No solar or house battery at present.
Staying with Octopus, they don't recommend Cosy for EV owners.  I think it is more complicated that.  Cosy would definitely almost double the cost of charging the car.  On the other hand, in the winter it might well be cheaper to be on Cosy than to stay on Intelligent Go.  Battery storage might help with load shifting but large capital cost.  If buying a battery, maybe best option would be Cosy in the winter, Intelligent Go in the summer, storing grid electricity and charging the car in the cheap rate periods.
Ovo looks interesting because it seems it would be possible to have Charge Anytime for the car and Heat Pump Plus for a heat pump (as long as it was the right brand).  I'd expect to be safely cheaper than gas for heating as long as I had a decent heat pump installation.  On the other hand, I would lose the ability to save money by running the washing machine and dishwasher on the cheap rate.  An extra complication is that if I wanted to install solar and have Charge Anytime, I would need a different car charger.  That's a pity because I've got a pretty new Ohme epod that I had installed especially because it worked with both Intelligent Go and Charge Anytime.  Apart from the cost, it just feels like an awful waste to replace it so soon
So that's all pretty complicated and I've only looked at 2 energy suppliers so far!
Matthew
@matthew_w
It's a complex area and every case is different so in fairness to the podcast difficult to summarise.  It also changed frequently.
I have a heat pump, EV and solar panels but no battery.  I did some modelling and eon next drive turned out best.  In fairness there wasn't much between a couple of leading options.  I'm locked in for 12 months because of the export tarrif (and my import tarrif is guaranteed for 12months.  I see it as an annual job.
(@andris)
Here is my update on the move to Eon Next drive.  Customer service is a bit slower than Octopus, but the tariff is great.
They couldn't read my smart meter for about 4 months, which was the most expensive time of the year. December to March. They said that I will be charged the normal price, but they will refund me the money once the meter starts working. I'm copying their response here. It took a few calls and a few months, but we finally got there.
Hello Andras,
We’ve just reviewed your account and found that we did not receive some Half-Hourly data from your smart meter.
But don’t worry! We’ve added our Standard Variable tariff to your account for the affected days and have manually calculated the difference between this and the NEXT DRIVE FIXED V5 tariff to credit your account to ensure you’re not losing out.
Here’s how we worked this out:
Half-Hourly reads not received between 10/12/2024 and 01/01/2025, 01/01/2025 and 05/03/2025.
Your average usage split is: Day 19.68%, and Night 80.32%. You had a total of 85 days missing half hourly data, which had a total combined usage of 4239Kwh. With these periods billed against the Standard Variable Tariff for their respective periods the total cost is £1081.27. We have applied your average usage splits and their respective tariff rates to these days which comes out at a total cost of £484.
In order to make sure you’re not losing out, we have credited £597.26 to your account which will show on your bill as credit.
Sending Positive Energy,
E.ON Next Team
(@agentgeorge)
@arundalep Do they check you have an EV, what if you buy an EV and sell it, do they then automatically take you off the EV tariff.
What about if you say yes to getting an EV, but then cancel the order as import tax gone up so you're delaying the purchase.
(@arundalep)
@agentgeorge for Octopus Intelligent Go, yes you need either a compatible vehicle or charger. The onboarding process includes setting up the vehicle battery size and carrying out a test charge (controlled from their end). The huge benefit to Intelligent are the ad-hoc off peak periods during the day, especially if you have a heat pump and battery storage. If they detect a lack of charging activity they will kick you off the tariff.
Standard Octopus Go, I don’t believe they have any way to verify if you actually have an EV so even if you have to agree to having one, they can’t prove either way.
Hope that helps
Sunamp for hot water storage.
Insulation upgrades:
EPS cavity wall insulation.
(@agentgeorge)
@arundalep good advice about needing an EV to stay on the tariff.
when I joined Octopus, I did their quick questionnaire to match my system to their best tariff.
It works better if you have an Octopus compatible Battery and EV socket, its not a charger as that is in every EV, currently limited to 11kW max.
I have growatt which is not on their list, so cant make use of the intelligent tariffs.
i found out recently when I had a power outage, you have to spend around £1k to upgrade the system to off grid use. I didn't ask what you got for that, it was ridiculous on cost.
(@andris)
@agentgeorge Not with Eon Next. The only reson I left Octopus as they said i can't have intelligent octopus for 7 hours as I have no EV. I was on Octopus go for 5 hour EV time paying 8.5pkw. Then I moved to Eon Next as u can have 7 hours at a tarrif of 6.75p/kw.
I’d be interested to know if anyone uses the NetZero app with Tesla kit to control their energy importing with a TOU tariff please. With the impending charge being levied on the advanced features NetZero provides, automation functions will require a monthly subscription to enable them to be used.
I realise that the developers have to live and eat; however, on a purely selfish level, would this automation to use perhaps OE’s Agile tariff be an economic proposition to the user please? Regards, Toodles.
(@old_scientist)
I don't (yet), but my PW3 is due to be installed shortly and I was planning on using NetZero for automations. However, at $69.99/year, I feel that will likely more than offset any savings I may make. I'm not aware of any other apps that allow easy integration of the Agile tariff.
If I were a Tesla/Agile user, I think I'd just manually set my tariff in blocks throughout the day using Time-Based controls based on whether I wanted to import or export during those times. Although the half hourly rates change daily, the pattern they follow is pretty much the same and can be segmented into time blocks (e.g, midnight to 6am, 6-10am, 10am-4pm, 4-7pm, 7-10pm, 10pm-midnight). Analysis of the last 12 months of data should allow average prices to be set which would allow the Tesla AI to work out a general operating pattern.
This post was modified 2 months ago 2 times by Old_Scientist
This post was modified 2 months ago by Mars
@old_scientist I cannot locate the discussion on Octopus Intelligent Flux, so please excuse my appending my update here.
Intelligent Octopus Flux versus Octopus Cosy.
I promised to review my use of Intelligent Octopus Flux with my previous experience using Octopus Cosy.
Before I give any figures or express my overall feelings of one tariff versus the other, I should state that it was a very short period of a trial and obviously just one very narrow based sample and may not represent typical use for anyone else! In addition to this, perhaps April might have been a little early for a switch to such a tariff and the results of such a trial from say June to September might be very different. Due to the billing periods involved and my inability to extract more accurate details, I have decided to take the monthly summaries from my Octopus Energy app; though I used the IOF for six weeks, I am using the figures for just April as these were far easier to extract than it might have been had I added the first 15 days of May as well.
My ‘consumption’ for April 2025 = 1051 kWh.
My consumption for April 2024 = 1039 kWh.
My ‘export’ for April 2025 = 1226 kWh.
My export for April 2024 = 1088 kWh.
Please note, the 2025 figures involve battery charging to 100% daily and forced discharge to 20% from 16:00 until drained. The 2024 figures by comparison are those of ‘normal’ battery charging and consumption grid use and the normal solar production exported. I might add that in fact, the solar production was higher this year than last as April produced some 944.8 kWh compared with 722.8 kWh in 2024.
The actual ‘bottom line’ figures are:
April 2025 consumption = £250.56
April 2025 export = £327.91
April 2024 consumption = £102.29
April 2024 export = £163.26
Therefore, 2025 showed a ‘balance’ of £ 77.35
and 2024 showed a ‘balance’ of £60.97.
(NB, all figures include any standing charges and VAT where applicable)
Feelings: ‘Thrashing’ the 27 kWh battery by discharging approx. 22 kWh every day and leaving me with ~5 kWh of reserve for eventualities, which, if used would result in me having to use the grid at a higher cost to cover any further demand, left me feeling uncomfortable. I also felt that the IOF control algorithm left room for some refinement; I found that on many days, the system would be force discharged to the 20% level (and then further discharged by a further ~2%) then, whilst still at the highest unit cost, start recharging the battery! I had to override the control software to minimise this problem but it did not fill me with confidence about OE’s software! This quirk did feature in my final decision as I felt the scheme needed refinement.
I understand that the whole idea of IOF is to provide the grid with a ‘reserve’ for the highest demand 3 hourly daily period and that by an elevated export rate, the participant would benefit financially even with the higher grid consumption rates. In addition to this, some discussion on RHH suggests that such schemes aren’t necessarily helpful or kind to ‘the grid’ as they neither help in phase balancing or evening out demand at times of greatest demand.
Having tried out the IOF tariff for some 6 weeks, I reverted to Cosy as I felt it was a ‘safer and easier’ scheme for me. YMMV of course.
Regards, Toodles.
(@old_scientist)
Thanks @toodles for the update.
My PW3 is due to be installed this week, and I'm going to give IOF a go. Accepting that Octopus will fully cycle the battery daily, I think this will be the most lucrative tariff for me during summer as we will be large net exporters, and an effective day export rate of 22.36p and a peak export rate of 29.82p are 149% and 199% that of the standard SEG rate of 15p. The more you export, the greater the benefit.
On any other tariff, I'd simply charge from solar and used stored solar overnight as our summer usage is around 10kWh per day and we will generate that on 99% of days in summer, so the cost of import becomes largely irrelevant, and IOF substantially beats SEG rates for export. We'd still be cycling the battery daily, although maybe not as deep (down to 20%) as Octopus will. Is there a benefit of discharging to 20% or only to 50% before recharging?
Financially, I think your timing was not the best as April and October are clearly crossover months for me, where usage and generation cross. Your data syggests similar as there isn't a huge difference between your consumption and generation figures.
I get the frustration of the battery exporting past it's 20% reserve and then recharging at peak rate. As it's a net cost tariff, I think you just have to view that as being cost neutral overall - you've exported a little more at 29.8p and then paid 29.8p to put it back again. Obviously there will be a small loss to you in the round trip losses you suffer in the inverter conversions.
I've modelled my numbers, and I cannot get close to the financial benefits of IOF during summer assuming a 15p import/export price on a tariff such as Cosy, so I think I'm going to give IOF a go for the remainder of this summer and then switch to Cosy in Oct as soon as the weather breaks and the heating goes on.
One other thing I'd appreciate feedback on is how you found the switching process between Cosy and IOF, both on to and away from IOF.
This post was modified 2 months ago 4 times by Old_Scientist
@old_scientist I found the switching between tariff just slightly irksome as even though when requesting to change and asking for notification of when the switch would take place so that I might adjust my schedule, I was only informed retrospectively that the change had been made for me!
I’d be interested in knowing how you get on with IOF in due course please.
Regards, Toodles.
Page 42 / 46
