Open Energy Monitor
@editor The EmonPi unit is plugged into the mains and the other items are plugged in to the EmonPi.
Ive attached an image of my heatmeter, the grey wire coming up is connected to a USB to modbus adapter like this DSD TECH SH-U10 USB to RS485 Converter for Modbus: Amazon.co.uk: Computers & Accessories and then into my EmonPi. It was a bit fiddle to get the data from the heatmeter, but thats because I was bolting it onto a previously bought emonPi rather than buying the heat pump monitoring kit
- 2,114 Topics
- 46.4 K Posts
- 57 Online
- 3,410 Members
@jamespa Thanks. I did not instruct them not to insul...
By Eliuccio , 13 hours ago
By Grantmethestrength , 13 hours ago
@trebor12345 I must admit I noticed that about Hitachi ...
By ASHP-BOBBA , 15 hours ago
By Brendon Uys , 3 days ago
By Burtis , 3 days ago
By Old_Scientist , 4 days ago
By Lucia , 4 days ago
By Ashfp , 5 days ago
By Transparent , 6 days ago
By Mars , 6 days ago
By Mars , 1 week ago
By Prunus , 1 week ago
By marcinwloch69@gmail.com , 2 weeks ago
By JamesPa , 2 weeks ago
