That's the way to go @batalto The cost of lithium batteries has been steadily falling whilst energy-prices have been rocketing.
That means the break-even point is now surprisingly short.... around two years.
At the beginning of this week my local Borough Councillor wrote to tell me that a West Country dairy farmer was paying about £5 per cow per month to keep the milking parlor and bulk storage tank running. For an average-sized herd with two milkings each day, that equates to a £1000 electric bill per month.
I will be contacting local dairy farmers as a matter of urgency. They need to know that there are alternative strategies available.
@editor - I don't know if you're still 'in contract' or have dropped onto the Standard Variable Tariff. This affects what you might wish to complain about.
However, the Ofgem guidance for Energy Suppliers is that they can require a customer on monthly direct debit to keep sufficient funds in their account that they cover at least the following month's bill. That rule reflects the fact that we are effectively paying in arrears. The first year of a new contract consists of 11 payments, not twelve.
If your Supplier is increasing your DD beyond this then you have the right to demand that the monthly payment is reduced.
Some Suppliers are now increasing DDs on the basis that the customer's account would be in debit by the end of the contract term.
That reasoning is sound, but only holds true if that customer is actually within a contract. The logic can't possibly apply to consumers who are simply using the Standard Variable Tariff because the Supplier can't possibly predict when they will switch to a different Supplier.
I have been briefed as to how the complaints system should work by a very helpful employee at the Office of the Energy Ombudsman. The first step is to download a copy of the actual Complaints Procedure from your particular Supplier. They are not all identical!
I also strongly advise against using telephone calls to handle any aspect of a complaint. You need proof that the process has been followed in order for the case to be accepted by the Ombudsman. Email is the best option because you retain a copy with a date/time stamp.
@robl, we've spent a lot of time insulating the property – just did a stint this week sealing gaps between window frames and we're going to be 'painting' the house with a masonry cream this summer that will lock in more heat. From a heat loss perspective we're quite pleased with where we are. Despite all of this, running the heat pump 24/7 will still consume well over 50kWh on mild-cold days because the heat pump is just ticking over. At current and potentially higher tariffs come October, this starts to become unaffordable.
The case for batteries is undoubtedly stronger than it has ever been and it's something we're looking at very seriously.
@editor if you are looking strongly at batteries I would recommend you DO NOT go with what installers offer you. They are well overpriced. If you want easy get the 5kwh pylontechs. £1500 for 5kwh is the cheapest premade battery you are probably going to find in the short term. They are literally plug and play as long as you have a hybrid inverter/charger.
https://www.itstechnologies.shop/products/pylontech-us5000-4-8kwh-95-d-o-d-battery-storage
Whether you go with what installers recommend depends on how you intend to deploy the batteries.
If they are configured as part of a set up which includes the possibility of grid-export, then you are constrained by the regulations around MCS accreditation and G98/99 export approval from your DNO.
OTOH, if you are heading in the direction of off-grid storage to run 240v AC equipment (as I am) then there are very few rules which apply. And that includes safety regulations!
A hybrid off-grid installation means you'd be paying about £2000 for 14kWh storage with BMS (Battery Management System). But you then need to learn how to put it together with the right tools.
You pay a hefty premium to manufacturers of off-the-shelf storage batteries, such as Pylontech, to avoid learning the DIY approach.
@transparent I wonder if your dairy farmer heard: https://www.bbc.co.uk/programmes/m00120bp where they cool their milk for daily storage by transferring the heat from the milk to warm their swimming pool, then use the heat from the pool to warm the milk back up for producing cheese (if I remember correctly).
Posted by: @transparentA hybrid off-grid installation means you'd be paying about £2000 for 14kWh storage with BMS (Battery Management System). But you then need to learn how to put it together with the right tools.
Is that £2,000 for all the kit?
That's £2000 for the battery cells and the BMS, which is the electronic box that provides balancing and protection. I'm including an approximate amount for (thick) cables, a fuse and a trip.
You'll need to house them somehow. The cells don't run hot, but a busbar bolt which isn't at the required torque will heat up. So I've used some off-cuts from Fermacell, a cementatious wall-board.
You could equally well decide to use a kitchen wall cupboard. It's about the right size, but try to buy from Howdens because they use the more substantial 18mm thick high-density chipboard.
On top of that you require an inverter. The type depends on what you're trying to achieve. Allow £1000+.
I'm already having this conversation with others. See the dialog between @batalto and I over here a month ago.
@transparent to be fair you don't need to spend £1k on the inverter. Mine is just the Sofar ME3000SP and they aren't that much. You can even get used one on eBay for a few hundred.
https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=sofar+me3000sp&_sacat=0
Posted by: @bataltoto be fair you don't need to spend £1k on the inverter.
That's true. But I'm also allowing some headroom for the double-pole mains isolator, cabling, mains changeover switches, trips and the DIN-rail enclosure.
The ball-park figures I've just given should be sufficient for @editor to decide whether to buy-in server-rack batteries such as PylonTech offer or proceed down the DIY route.
There's a bit more to this than just bolting the bits together.
You need crimp-tools, torque wrench etc. and a qualified electrician to make the mains connections.
And there's some background knowledge required, such as how to first connect the battery to the inverter without the inrush current to the capacitors blowing the logic on the electronics board.
Even so, that still leaves a huge gap between the cost of the DIY route (off grid) and getting pre-built modules installed by a professional.
As I'm a designer, I don't see myself wanting to start up a supply/installation business for the required DIY component parts.
It's no threat to me if this Forum becomes another of the online places where end-users can find out how to build their own off-grid battery system.
Hi Newbie,
Because of its high specific heat capacity, water makes an excellent means of storing heat energy. I feel we should be making more use of this to help reduce our carbon footprint.
Currently viewing this topic 1 user ( IaAck ) and 12 guests.
Recently viewed by users: Old_Scientist 1 hour ago.
- 2,255 Topics
- 50.2 K Posts
- 768 Online
- 5,915 Members
Home Assistant also has an auto-entites card so you can...
By Grantmethestrength , 13 minutes ago
RE: PV Panels on roof in Conservation Area
@jamespa Thanks for the input James, recording Oil usag...
By colinc , 39 minutes ago
@dgclimatecontrol - you have awoken me from my several ...
By batalto , 55 minutes ago
@jamespa mine seems changing albeit not by much, 3.21, ...
By AdamK , 2 hours ago
@majordennisbloodnok The migration hasn't started in th...
By HCas , 2 hours ago
RE: Radiator Sizing Dilemma: Vertical vs Type 33 for Low-Temperature Heat Pump Systems
Yep that's it, but the current design would re...
By DREI , 3 hours ago
There won't be many RCBOs with a 100mA trip rating beca...
By Transparent , 3 hours ago
Because its what the investors demand, simple as that. ...
By JamesPa , 4 hours ago
RE: One room is colder than the rest of the house
@jamespa thanks for all the advice. Just so you know, ...
By AndrewJ , 6 hours ago
RE: Mitsubishi Ecodan R290 10kW performance
@dgclimatecontrol I only have 1 cylinder and I can conf...
By Ecoste , 6 hours ago
RE: Daikin Octopus installation update - I saw my first defrost. 😍😂
My MMI is in the loft but I checked the pump flow rate ...
By RadWhisperer , 7 hours ago
RE: Grant Aerona 3 and Drayton system questions
Good man/woman that plumber! Very likely....
By JamesPa , 7 hours ago
RE: New build installation query
@paullacey Hi I have managed to save the fil...
By JamesPa , 8 hours ago
Thanks for the response @batpred Your conversational ...
By Transparent , 10 hours ago
RE: What should we do with our Aga?
One slightly off-the-wall suggestion is that, if you li...
By Majordennisbloodnok , 11 hours ago
RE: My experience with 3 heat pump surveys: Heat Geek, British Gas & Octopus
If you paid for any of the assessments try asking for t...
I've created a separate post here, wondering about radi...
By DREI , 1 day ago
@ecoste, @walnut-tree-cottage these are both great piec...
RE: Solar inverters - where does the energy go when clipping?
You will, of course, check the dimensions and weight be...
By Transparent , 1 day ago
