[Solved] Hot water issue, never seen this before: Grant Heat Pump and Cylinder
Hi all. A faulty mixer valve sounds like a likely cause to me too. Failing that there could potentially be some cross-flow going on; I notice on the photo of the combination pressure reducing valve, that the balanced cold outlet is plugged. Maybe there's a point in the system at which the higher-pressure cold supply is overpowering the reduced-pressure hot supply, travelling the wrong way down the hot draw off, and subsequently cooling the top of the cylinder down. A bit of a long shot, but this could be something to explore if a mixer valve issue is ruled out.
hi Tom, thank you and thanks to everyone else who replied.
it turned out to be a faulty shower that was causing the issue. This was closed off by a plumber and it fixed the issue straight away. Has now been replaced.
took 3 different plumbers to figure it out but we got there. Nothing to do with the pump or cylinder in the end.
- 2,114 Topics
- 46.4 K Posts
- 33 Online
- 3,410 Members
@old_scientist Cosy is a really good tariff for heat pu...
By ChandyKris , 4 hours ago
By Lucia , 5 hours ago
By Lucia , 6 hours ago
By Ashfp , 11 hours ago
By thewiseoldbird , 1 day ago
By Prunus , 4 days ago
By Mars , 5 days ago
By JamesPa , 7 days ago
By Transparent , 1 week ago
By Wh0am3ye , 1 week ago
