Why do we need pressurised systems?
Having had a second occasion where the system pressure for the heat pump dropped to zero (under investigation at present) I go to wondering:
Why do we need a pressurised system in the first place? I have always assumed that a positive pressure is used to ensure a constant supply of water to the pump(s) thus reducing air bubbles which would be purged from the system during circulation and possibly also to avoid risk of cavitation in the pump impellers.
Have I summed it up correctly or am I nowhere near the truth - is there something else I have not thought of perhaps?
Curious Toodles.
@iaack I enquired of Wattson and the reply was very much along the lines of that which I surmised Holmes.
Posted by: @toodles@iaack I enquired of Wattson and the reply was very much along the lines of that which I surmised Holmes.
@toodles Is that because the AI has searched the forum for information, and has found and paraphrased your own question and assumptive reply back to you, reinforcing your own assumptions (which may well be correct). Just surmising 🤣
@old_scientist If that were the case (and it might well be the case I suppose!) perhaps Wattson would be a bestie to a certain President 😉. Oops, Sorry! No Polyticking! Toodles.
A good question @toodles. My old open thermal store and oil boiler chugged away quite happily, if expensively, unpressurised. But the header tank was sat right on top of the thermal store in the airing cupboard, with stagnant water sitting at a cosy 30-35degC breeding and growing all manner of questionable organic produce inside it. 🤢
Pressurisation and sealed systems eliminates the crusty & stinky stagnant header tank issue, and almost completely eliminates risk of pump cavitation. There's a net positive pressure at the pump suction inlet far higher than the minimum the pump requires, and at all points in the pipework system for that matter, making pump or system cavitation anathema. So it doesn't really then matter where in a sealed system the circuit the primary and any secondary pump are placed - they'll do what they do, pumping water. It also usually means a quieter running system with less air entrainment & gurgling.
A sealed system eliminates many corrosion risks. Air in systems promotes internal corrosion. Corrosion needs an oxygenated environment to thrive. No air = no corrosion, theoretically.
And yet installers still do strange things, such as fitting auto air valves on sealed pressurised systems. Open system + auto-vent - yes. But sealed system + auto-vent, er, why? Over time the vent will open, and pressure will be lost. I much prefer a manual air vent, which I can open up to let air escape and then check the system pressure on the gauge and top up slightly with the filling loop if need be. A month or two after system filling no more air separates out and, provided the system is holding pressure, the manual vent never needs checking.
- 2,342 Topics
- 53 K Posts
- 828 Online
- 6,000 Members
RE: External pipework insulation
Question the current insulation you see, does that look...
By jeegnesh , 58 minutes ago
RE: Controlling Daikin Altherma via P1P2 and Home Assistant
@majordennisbloodnok That’s correct. I can’t find anywh...
By weoleyric , 6 hours ago
@andrewj yeah we recreated it. Engineer seemed to think...
By swwils , 7 hours ago
That's a good spot and a valuable insight, @sheriff-fat...
By Majordennisbloodnok , 9 hours ago
@majordennisbloodnok And did ‘Honey’ order it for you? ...
By Toodles , 10 hours ago
@robs — thanks again for your detailed comments. Some r...
By cathodeRay , 23 hours ago
@papahuhu I hope you get a swift resolution. Regards, T...
By Toodles , 1 day ago
RE: Poll for Time of Use, tariffs, technology
That’s fine by me too Major, I feel it is a sad reflect...
Bingo. Sometimes a judiciously placed size 10 bovver bo...
RE: Mitsubishi Ecodan 11.2kW heat pump with low COP
@ciocoiu-alexandru I can't provide the same level of di...
By Sheriff Fatman , 1 day ago
The three technical issues I'm considering are: BMS...
By Transparent , 1 day ago
@transparent Your post may fit better in th...
RE: British Gas vs Octopus Energy vs Heat Geek vs EDF vs Aira vs OVO vs EON.Next vs Boxt
@jamespawhite, if you could be bothered, you could also...
I've got a bit of time to draft something today, so the...
RE: Help with heat pump sizing
@amin I dont think materially relative to t...
@majordennisbloodnok I have decided to take the plunge....
By TechnoGeek , 2 days ago
RE: Different dT on each radiator?
I cant sorry. Its based on some calculations I did fro...
