PWM pump or not?
I'm not turning it off. I like the idea that it can run every 24h , if the manufacturer felt that was needed by design, I'm going to let it. I have large PV and batteries, my electricity is essentially free during summer season, so even if it is 100W, I'm not bothered.
Also regarding the actual standby figures, I'm getting 100W with a CT clamp but I think its far too inaccurate at low levels. I did calibrate but just not sure its right tool for the job.
I now have a proper SDM120M meter installed on the outdoor unit feed . I haven't yet go round to running the modbus connection to it but every time I take a look on its screen now, its showing only 7W. The mfr spec for standby power is 22W. we'll see. of course I need to monitor the indoor unit and pump as well, got another SDM120M for that, but thats not installed at all yet.
by the "covered/masked" question - do you mean the indoor PCB? yes it does have the cover on. I'm enough of a heating nerd to check my graphs every day (Even in summer). don't want to sit in the airing cupboard watching a flashing light 😉
Posted by: @iancalderbankby the "covered/masked" question - do you mean the indoor PCB?
I meant the heat pump, where is it placed? the outdoor temp seems to drop a degree or two when the hp runs. So either the air temp thermistor is seated next to the evaporator coil or the air temp drops because the hp recirculates the air, or any other reason why that might be.
@fazel ah yes. that looks the behaviour I see in my graph. I can't remember posting that one though, did they finally put me on the public heatpump list? I have also noticed that outside air reading drops a bit when the hp runs as you saw. Its installed as per mfr recommendations for air clearance, plenty of space for the fan exhaust to go out into but there is a wall to the side that might be ducting air draughts around, I'm not sure. I've got room to move it if so. I also don't know where the air temp thermistor is on the unit either. one for me to look into , but not for a while. actually I just realised there's a photo of my outdoor unit in here
@iancalderbank 99% it's in the back, if it's too close to the evaporator it can trigger the system to have a lower evaporating temp, or to put out a higher capacity in the weather compensation calculation.
you can actually play(insulate) with this sensor, make it think the air temp is higher, like 2-3 degrees and see if the hp modulates lower thinking it's warmer outside.
As an example
"I have such a wifi relay board with which I automatically arrange the following things.
1 = Power determined based on outside temperature (+10 = 50%, between 0 and 10 degrees = 75%, <0 degrees = 100%)
2 = I have 2 fake sensors, 1 is dedicated at 38 degrees, if Tbuiten = + 20 degrees the WP thinks it is 38 degrees so it modulates further back ( 20 Hz). And I have a fake sensor that is dedicated set to 14 degrees, if Tbuiten is between 4 and 20 degrees, the WP thinks it is 14 degrees so that the WP modulates back to 20 Hz.
From <4 degrees, the "real" mitsu sensor is active to make crazy things like flash injection and rev up fans work properly.
And this actually works really well!! It now runs smoothly at 26Hz, while this is not possible "from the factory", because Tbuiten = 8 degrees ATM, and then the Mitsu normally does not go further back than 30Hz.
The "REAL" temperature on which everything is controlled is measured by a Netatmo weather station of mine, and NodeRed in combination with HA controls everything."
https://gathering.tweakers.net/forum/list_message/70446450#70446450
Use browser translate
Posted by: @iancalderbank@fazel ah yes. that looks the behaviour I see in my graph. I can't remember posting that one though, did they finally put me on the public heatpump list? I have also noticed that outside air reading drops a bit when the hp runs as you saw. Its installed as per mfr recommendations for air clearance, plenty of space for the fan exhaust to go out into but there is a wall to the side that might be ducting air draughts around, I'm not sure. I've got room to move it if so. I also don't know where the air temp thermistor is on the unit either. one for me to look into , but not for a while. actually I just realised there's a photo of my outdoor unit in here
I believe that the air temperature sensor is normally located at the rear of the outdoor unit, before the evaporator, so that it gets minimal effect from heating or cooling occurring within the unit. Obviously when the fan is stopped there could be some slightly warmer air circulating from inside the unit.
- 449 Online
By trebor12345 , 3 minutes ago
By L8Again , 5 minutes ago
By cathodeRay , 39 minutes ago
By Batpred , 1 hour ago
By cathodeRay , 1 hour ago
By AndrewJ , 2 hours ago
By benson , 3 hours ago
By Batpred , 7 hours ago
By GC61 , 9 hours ago
By JamesPa , 23 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
