Heat loss calculators and spread sheets
15 Users
24 Reactions
20.9 K Views
Posted by: @lakey
How did they adjust the fabric sheet, by just ensuring the total output from the radiators in the house balanced the total heat loss/energy usage even if room by room it didn't match?
Pretty much that, basically (1) make sure that the fabric model represents the actual fabric and (2) adjust the ACH to fit measured loss.
Here is the data I used.  This is 2 years worth but 1 would have sufficed
downfield
(@downfield)
Posted by: @lakey
I'll dig deeper into a fan coil radiator.
Have a look at Jaga Strada units.  We have them everywhere and they work well.
You can set low  medium or high fan speeds at a given flow rate, which changes the heat output (and presumably the DT) without changing the flow rate.  We leave ours set to the lowest speed, which is very quiet.
Posted by: @lakey
I've downloaded half hourly from Octopus, I think they gave it in gas m3 though
Yes, most meters (including all Smart Meters) record gas consumption in cubic metres (m³)
To convert to kWh...
Cubic meters (m³) used x calorific value x Gas Correction factor (1.02264) ÷ conversion factor (3.6) = kWh
The calorific value (CV) of gas varies slowly across the UK daily, and there are 69 daily sample points on the network.
The CV used by your energy supplier is printed on your bill.
It will be figure around 39 MJ/m³ (MegaJoules per cubic metre)
You can obtain the CV for all sample points across any range of dates via the Gas Data Portal.
CV data comes under Supplies - Daily Actuals (physical) - Calorific Value
then choose the date range before selecting View Data at the foot of the page.
Page 9 / 9
