Heat loss calculations and how they work in conjunction with heat pump sizing
12 Users
19 Reactions
12.7 K Views
Topic starter   [#1721]
Kicking off a New Thread: Heat Loss Calculations
We’ve just released the latest episode of Homeowners’ Q&A, where we dive into heat loss calculations and their importance in sizing heat pumps correctly. Our panel – featuring Michael Crook from Heat Pump Installers UK, Graham Hendra, and @jamespa (from the Renewable Heating Hub community) – discusses why accurate heat loss calculations are critical to ensuring your heat pump is the right size for your property.
We cover common issues that arise from inaccurate calculations and how homeowners can avoid costly mistakes. James shares his personal story of how incorrect heat loss surveys nearly led to an oversized and inefficient heat pump installation.
Special thanks to One Heat Loss for sponsoring this episode. They specialise in providing independent heat loss calculations for both homeowners and installers. For more information or to take advantage of their special offer for Renewable Heating Hub members, email your plans to info@oneheatloss.co.uk, mention Renewable Heating Hub, and receive an automatic discount!
Got questions about heat loss calculations? Drop them below.
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
(@Anonymous 5011)
I have zero issue with a heat pump being oversized. Actual house loss at -3 is 3kW and our installed heat pump at -3 is 6kW. So able to deliver double the heat demand. However we get -9 a few days a year, so zero issue caused by that. Plus we have been able to also heat a summer house 24/7 for nearly no cost.
I could of quite easily installed a 4kW unit, but at -9 the output for heating and DHW would have a unit too small.
Yesterday we had an average daily temp of 8 degs, so heat delivered average was 1.4kW to heat the house and summerhouse over the day. Space heating CoP was 5.3, with the shortest run of 20 mins and longest just over an hour. This morning we had 3 degs and no defrosting was needed either.
Downside it took a bit of extra setting up. But a full open system helps so there is plenty of engaged water volume. System design was just simplified as far as possible, so nothing gets in the way of the heat pump controlling things.
(@wino99999)
I did my own heat loss calculations when sizing my boiler for renewal around 15 years ago, I also ended up over sizing the boiler because I didn't want to be in a position that I selected a boiler that was undersized. My cousin was a Corgi registered gas fitter, but old school with respect to boiler sizing, i.e. replace like for like... which I didn't want to do as I had an old floor standing Ideal Mexico RS80 I think 70-80,000 BTU's, it was a long time ago.
Can anyone recommend a free online heat loss calculator that is accurate and takes into consideration the room aspect wrt external walls their size, construction, window sizing, type and orientation, floor types, room type and temperature above/below, roof type and insulation. I would like to be able to play with different scenarios/materials i.e insulation, window types (triple glazed, type of gas and air gap sizes etc), loft insulation (different amounts of insulation, thickness and type plus location i.e roof line or floor of loft) etc etc. I also wonder about insulation to ground floor concrete screed and installation of UFH in order to be rid of rads.... but this might be 1 step too far?!
Ideally it would be useful if the model for house could be setup and these variables changed piecemeal to find the most economical next step to reducing my carbon footprint. I think I've done everything that is cheap and economical to do myself - i.e insulation, re-installation of replacement uPVC windows because they did such an appalling job (previous owners had some cowboys in), draughtproofing, insulation especially the draughtproofing of a raised floor garage conversion, etc etc.
I live in a southern 4 bed detached house Gas usage 7600kWh/Yr Electric usage 2000kWhr/Yr, 4kW Solar with 3.6kW inverter, plus a home grown PV diverter when the sun shines (no heating gas usage for most of around 8-9 months of the year)
I've been considering a Battery in addition to my Solar as well as increasing my array size - tried to get info of the consequences of doing this to my SEG (Jan 2012) from Octopus and i'm getting nowhere. Plus after the 1st 4kW of Solar install its quite difficult to cost in any upgrades...
I would be interested in examining the cost of a Heat pump given my Gas Bill (the gas only element) is only around £500/annum and gas is considerably cheaper than Electric per kWh...
Probably a lot to digest and take in here and it probably is not all relevant to heat loss calculations, but mostly it all ties in!
P.S. Thanks Mars the video was a good one!
MG4 EV and Zappi, Hanchu 3.8kw Inverter 9.4KWh battery, 4kw Solar installed Jan 2012, Aurora One 3.8kW Solar PV inverter.
1974 4 Bed Detached with loft and wall cavity insulation, all radiator.
(@judith)
Heatpunk is very good and I was able to get an accurate result from that https://heatpunk.co.uk which agreed with the sanity check of the annual gas bill.
if you want to do more sophisticated things like solar load or wind chill you need a passive house model (I got an old version demo model). No plumber model ever uses things like that.
The most unknown variable is heat loss due to air leakage. The defaults are tied to year of build & relevant building regs, which are not always achieved or you may have done work to make it better. We had a pressure for measurement, ~£300 and it was well worth it. Eventually potential installers (with some badgering) were able to use the true value.
Posted by: @judith
The last sentence makes my blood boil!
In what other industry would it be acceptable to insist on basing the key design parameter (heat loss) on data known to be suspect, when in most cases there is good data available (consumption) that takes into account the known uncertainties, and from which the key design parameter can be readily calculated?
The heating industry led us astray in the late 90s early 00s by setting up condensing boilers to run at high, constant flow temperature rather than at the low, preferably weather compensated, flow temperature that the boiler makers presumably intended.  As a consequence most of us have been paying 10% more for our heating than we need to, and 'enjoying' lower levels of comfort in addition. Furthermore 20 years worth of new housing stock has been built since condensing boilers became mandatory.  Had the heating systems been designed optimally for the condensing boilers, they would now be heat pump ready in terms of their space heating, but instead will likely need to 'upgraded'.
Yet here we go again.  Buffer tanks and wrongly sized systems poorly set up are being foisted on us, all for the benefit of the state-subsidised industry not the customer.  The worst part of this is that its well known what to do.  There are of course some speaking up against the poor practices and themselves doing the right thing to the extent that the rules allow.  However their voices are, it seems, being drowned out, probably by the grant harvesters who have no intention of sticking around, and just want a set of rules that guarantee they aren't liable.
We should be angry, why aren't we?
Posted by: @Anonymous
That's fair enough and at 6kW being oversized isnt going to make much difference, and furthermore you probably want the extra oomph for DHW reheat.
However the typical 8kW retrofit is a rather different prospect.  Oversizing may make the difference between:
  • needing planning permission or not
  • needing pipe upgrades (pretty disruptive) or not
  • radiators that fit and radiators that don't, or are obtrusive
  • an outdoor unit which dominates the space available, or one which slips in nicely
These are in addition to any (so far unquantified) performance penalty,
If the customer wants to have some spare capacity, along with any consequences, then (s)he is obviously entitled to request it.  Equally if the customer wants a system with just enough capacity, (s)he should be equally entitled to request that.  Currently the customer isn't given the facts, accurate data or the choice, and key available information is ignored in favour of a spreadsheet based on input data which is at best suspect.  GIGO (garbage in, garbage out) is a well known phrase in the computing industry and I would venture to suggest it may apply here.
(@Anonymous 5011)
Interesting fact from 2003 - 2 years before condenser boilers became mandatory.
Defra; the heating industry; the Energy Efficiency Partnership for Homes; CORGI; and City and Guilds, is launching the ‘Energy Efficiency Installer Certificate’. The aim of this initiative is to provide 70,000 installers with the skills needed to specify and install condensing boilers and properly advise consumers on high-efficiency heating systems. Following the completion of pilot courses in 2003, a series of ‘Train the Trainer’ courses were held in February and March of 2004, and the first of the Installer courses commenced in March 2004. We aim to pass 45,000 installers through the programme by 1 April 2005 and a further 20,000 (bringing the total to 65,000) by the end of 2005. The Training programme will be funded from April 2004 until March 2005 by the Learning and Skills Council, though initial funding to get the programme started will be provided by the Energy Saving Trust (with Defra support). The training covers:
a brief introduction to climate change and the Energy White Paper changes to Building Regulations coming in April 2005.
the elements of high efficiency system specification (boilers, controls etc)
Those successfully completing the training will receive a Level 3 City & Guilds Certificate – ‘The Certificate in Energy Efficiency from Domestic Heating
So no idea what this training content was, but think it fell on deaf ears and industry not willing to change, otherwise Weather Compensation PDHW etc would be common, not on the fringes of being strange.
Defra; the heating industry; the Energy Efficiency Partnership for Homes; CORGI; and City and Guilds, is launching the ‘Energy Efficiency Installer Certificate’. The aim of this initiative is to provide 70,000 installers with the skills needed to specify and install condensing boilers and properly advise consumers on high-efficiency heating...
Thanks for confirming that the industry knew what it was doing (wrong).
I guess it was just too easy to whack in an oversized boiler, turn it up to 75C, fit trvs and let the system sort itself out whilst costing the customer an extra 10% on running costs and compromising comfort.
Now we see similar behaviour, with the added incentive of a 7.5k government grant.
How to fix it?
(@judith)
When our condensing boiler was fitted 14 years ago (too big but who cared?) we were told very clearly that it only needed to be on high when winter was very cold.and at other times it should be lower.
But I forgot to turn it down again! This was the year before price hikes. So several thermocouple readings later we established we could save money by turning it down for most of the year. The boiler did not have weather compensation that came it 2 years later. The limit was 60C since it had no separate DHW setting,
BUT when we had some plumbing work done this year the plumber turned it up to 75 every time he changed anything. So some knew ages ago and some even now after all the advice on saving energy and bills still don’t know!
@judith Yeap, BG fitted a new gas boiler here some 15-16 years back and unbeknownst to me set the 24kWh boiler to 18 as the default setting. (After all, they were selling gas not paying for my consumption!) and as my house had a heat loss of less than half of that, it was not the best set up in the world. It was a condensing boiler but only one control for the DHW and heating 🤨 so I could not set it low enough. I am just a tad wiser now - and perhaps a little more cynical of so called surveyors from BG. Our ASHP runs a lot more economically than that BG spec’d boiler ever did!  Regrets, Toodles.
(@batpred)
Just wondering, and maybe this is a bit of a curve ball...
All these heat loss calculations may make sense on a new home but would it take much more than someone sticking a few temperature sensors around your home, add an external temperature sensor one and monitor gas consumption more finely (as most gas consumption is for the boiler). Then run it for over a year and you'd know how much heat you need from the ASHP and why.
But of course, someone with a combi boiler is mostly going to be wondering how to avoid finding/wasting the space to get a cylinder. And how to make sure the system can deliver that power on a direct air to water output?
GrahamF
(@grahamf)
@jamespa unfortunately, I don't think heat loss calculations can ever be terribly accurate.  Our house was built in 1968 and has a real hotchpotch of different floor types.  A few walls have different cavity thicknesses.  I am not sure whether the models take into account the fact that a house with a large floor area loses less per square metre through the floor than a smaller house.
Unless you measure ventilation losses, they could be a long way off.   Even if you measure them correctly, if you have a dog, you might open an outside door often to let it out.  At night, heat loss is lower because people close the curtains.  In the daytime, there could be solar gain, but only when the sun is shining.  A house that is wet from the rain will lose a bit more heat through evaporation.  When it is windy, convection loss from the outside of the house is greater.
Our gas heating bills gave an indication of heat loss, but we used to keep the downstairs temperature at 18-19C and turned on the upstairs zone for only a few hours in the evening.  We did not heat 4 out of 5 bedrooms.  Then, we turned the whole system down to 15C at night.  Now that we have the heat pump, we are heating the whole house as one zone and setting the thermostat in the hall to 20C for 24 hours per day.  They just aren't equivalent.
I did run an experiment where I turned everything on for a day in January.  The results were lower than the heat loss calculations, but I was not confident enough to trust the measurements.  Even if I had been confident, I am not sure that the installer would have shared my confidence.
One prospective installer said a 16kW heat pump was plenty.  Another refused to install less than 2 x 10kW heat pumps, because the risk was too great.  I decided to take a slight risk and install 1 x 15.5kW against a heat loss estimate from that installer of 15.1kW.  I intended to insulate my way out of trouble if necessary.  Now that we have real world measurements from the heat pump, it is looking as though we have a substantial safety margin.
My somewhat unscientific feeling is that you are doing well if you get your heat loss calculation within +/-30%.
Page 1 / 6
