Wattson has landed!
@judith good to know… I’ll continue to feed Wattson, and get it the point where all subjects and answers are consistent.
@editor No objection from me to using AI if it spreads the word. I personally use Perplexity quite a bit and find it helpful.
But as others have mentioned, the black box with text seems to pop up whenever you scroll back up the page and seems to reappear after every new page is loaded.
Would it be possible for a cookie to remember when you have dismissed the black box and stop it reappearing during set period- say 10 minutes?
Alternatively if you are a logged-in forum member, no need for the black box at all - we all know what the avatar means and the pop up could appear only on mouse-over.
@downfield That sounds like a very good idea to me, my magnified version is EXTREMELY ANNOYING and vexacious! regards, Toodles.
@downfield and @toddles, this isn’t in the settings currently. I’ll raise it with the developers and see what can be done.
- 37 Online
@morgan When you remove the cover most people will find...
By dgclimatecontrol , 2 minutes ago
@jamespetts If you have the space for a high capacity D...
By Toodles , 1 hour ago
@tim441 As you say Tim, very difficult to quantify any ...
@abernyte Our heating has come on twice in the last wee...
By Toodles , 2 hours ago
James, I would not question your findings and realise t...
By HCas , 3 hours ago
By jamespetts , 3 hours ago
By jamespetts , 4 hours ago
By HCas , 23 hours ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
By bontwoody , 4 days ago
