Most efficient use of NIBE GSHP with Solar PV
Hi @derek-m
Thanks!
I totally understand about the battery (and the VAT side of things). It's just that I've got a SolarEdge single phase inverter and that system wants a high voltage DC coupled battery and there are only two that are compatible: LG Chem Resu Prime, or a SolarEdge StorEdge. I just don't have the money right now (about 5-6k for the LG, about 7-8k for the StorEdge).
In fairness, I could install any old AC coupled system. But that means I'll have to buy another inverter on top of the SolarEdge inverter I've already got. I know it's possible. And maybe it's cheaper and will work equally well. It's just not very elegant, so I'm biding my time, looking at all the things I can do, and then deciding.
Out of everything, the cheapest, simplest thing to do is to get an iBoost.
We have a 4kW solar PV system which provides almost all our hot water from Spring through to Autumn. Even on cloudy days it can supply sufficient heat energy.
- 2,122 Topics
- 46.6 K Posts
- 77 Online
- 4,529 Members
By JulianC , 4 hours ago
You may well be right, @jamespa.
By Judith , 9 hours ago
By JamesPa , 11 hours ago
By Grantmethestrength , 12 hours ago
By dgclimatecontrol , 1 day ago
By Transparent , 1 day ago
By TRBob , 2 days ago
By normpang , 4 days ago
By ASHP-BOBBA , 4 days ago
