Will heat pump heat hot water without increasing the temp in my home?
If you can post a photo of the screen you've managed to access, then we will find the right manual for you.
Yes, there are several possible control units by Mitsubishi...
... and installers may also choose to use others anyway.
@transparent Thank you for the link to the user manual (bookmarked it). I am not seeing all the icons on my screen. Not sure why.
The page in the instruction manual shows all possible icons and their position on screen.
It doesn't imply that all could be present simultaneously.
Some combinations are mutually exclusive, and couldn't ever appear together.
@ellyse Is it possible that some of the icons you are not seeing on your own display are for functions that you do not have (naming of parts again!)? Often if a function is not required as it has not been fitted, then the setup for it may be suppressed to reduce clutter and simplify the display. Regards, Toodles.
- 2,123 Topics
- 46.7 K Posts
- 91 Online
- 4,531 Members
By Transparent , 9 hours ago
Thanks. It may be just Vaillant, not Grant, I just had ...
By cathodeRay , 9 hours ago
By Toodles , 18 hours ago
By Transparent , 18 hours ago
By Mars , 19 hours ago
By JulianC , 3 days ago
By Judith , 3 days ago
By dgclimatecontrol , 5 days ago
By Transparent , 5 days ago
By JamesPa , 5 days ago
By TRBob , 5 days ago
By Toodles , 5 days ago
By Mars , 6 days ago
