Will heat pump heat...
Will heat pump heat hot water without increasing the temp in my home?
10 Users
16 Reactions
If you can post a photo of the screen you've managed to access, then we will find the right manual for you.
Yes, there are several possible control units by Mitsubishi...
... and installers may also choose to use others anyway.
(@ellyse)
@transparent Thank you for the link to the user manual (bookmarked it).  I am not seeing all the icons on my screen. Not sure why.
The page in the instruction manual shows all possible icons and their position on screen.
It doesn't imply that all could be present simultaneously.
Some combinations are mutually exclusive, and couldn't ever appear together.
@ellyse Is it possible that some of the icons you are not seeing on your own display are for functions that you do not have (naming of parts again!)? Often if a function is not required as it has not been fitted, then the setup for it may be suppressed to reduce clutter and simplify the display. Regards, Toodles.
Page 8 / 8
