Weather compensatio...
Weather compensation - your questions
5 Users
4 Reactions
We are scheduling interviews on renewables and related topics for our Renewing the Conversation series and we’ll be kicking off our new series with an interview with one of the foremost experts on weather compensation.
If you have any questions about weather compensation that you’d like answered please drop them below or DM me.
@editor,
Mars, a question that comes up quite a lot is whether weather compensation should be used for ufh.
(@benseb)
Just posted a W on this. If using Weather comp, what to do overnight?
serms a clash between it being colder outdoors, so flow temp goes up. But then rooms need lower temp overnight..
(@batalto)
@benseb once you are at temp the power needed drops. That said you can adjust by a degree if you want to. There isn't much in it, but it seems to be marginally more efficient to drop the thermostat over night. In the end the pump will have to work harder later on to get the temp back. I think keV looked into it
262m2 house in Hampshire
(@alec-morrow)
Honorable Member Contributor
are there any experts in the U.K..
i’d happily volunteer on the back of my 3-400 installs over 15 yrs on boilers (the approach is the same for both boilers and heat pumps)
Professional installer
