Weather comp and set back?
So quick background.. I have an Ecodan 14kw, a 250sqm old house. FTC5.
Working well but keen to optimise.
We’ve been running in Weather Comp but with Tado room stats calling for heat (Rads upstairs, mix of UFH/Rads down)
I understand using the Tado stats isn’t great and we’re best trying to just use weather comp and tweaking until we get the best room temp. Perhaps set the stats +2c in case of solar gain or the log burner being on, but to turn off only (not call for heat)
My current lack of knowledge is around doing an overnight setback. Obviously we could easily do this with the Tado but it seems like what we SHOUlD be doing is reducing the WC curve by say 3c so it runs cooler overnight and therefore room temps go down. Otherwise we’re keeping the flow temp higher than it needs to be for no reason.
I can’t see anyway on the FTC5 to reduce the WC on a timer. It’s either on or off. I could fiddle with the +/- before bed/in the morning but I don’t like manual interventions!
Any ideas? Sorry if this has been covered before, couldn’t see anything from a search.
I agree it's a shame the FTC doesn't allow weather comp adjustments on a timer.
if you talk to tado they may be able to use the digital interface..which would make everything work in harmony..
you would need the EU extension kit though
THE uK extension kit is dumbed down for the UK
you
Professional installer
4 hours ago
1 day ago
3 weeks ago
Ecodan Zone 2 Mitshibishi thermostat Auto Adapt
3 weeks ago
Ecodan Pump Issues… Circulation pump turns off when heat pump compressor turns off
1 month ago
- 398 Online
By Majordennisbloodnok , 50 seconds ago
By benson , 5 minutes ago
By trebor12345 , 38 minutes ago
By RobS , 2 hours ago
By JamesPa , 3 hours ago
By Batpred , 4 hours ago
By GC61 , 5 hours ago
By cathodeRay , 9 hours ago
By JamesPa , 20 hours ago
By Batpred , 22 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
