@william1066 so my system did the experiment for me today.
I currently have a commissioned ASHP, the flow side goes to a 50L volumiser, then there is temporary shortcut (i.e. a bypass) back into the return side. I temporarily created demand so the ASHP has warmed up the water in the circuit and volumiser. the routes from the ashp's f+r circuit into the house are currently capped - there is no load on the ashp. the house is still on the boiler.
the graph starts when I got modbus working yesterday evening. RWT goes below 25 right at the start but nothing comes on. When Outside temp goes below 4C, the system switches the circulation pump on. But not the compressor. the lukewarm water in the circuit must be enough to satisfy the warmth needs of the outdoor unit. After that, the pump is leaving "off" gaps of 60 minutes then running for about 6-8 mins each time. I'm not sure what the "off" trigger is at the end of the "on" period. It'll be interesting to see how cool it gets before it puts the compressor on.
Posted by: @iancalderbankI'm not sure what the "off" trigger is at the end of the "on" period.
Probably just "x" amount of time
Hi,
I have the same Error F788 did you finally fix it?
Coule you please tell me Howell did you do?
thanks for tour help
@bobshopsupreme did you ever get this matter sorted out?
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
@editor Hello. Yes and no! The original problem was indeed a dead water pump, killed by contamination in the circuit and possibly the power cut during freezing conditions (we do have anti-freeze valves). It took two months to get a replacement part.
We have then had another 2 years of fun with shutdowns caused by low flow due to under-dimensioned pipes, and then we still have a contamination issue which seems to be coming from the radiators. At the moment the flow rate gradually decreases over several weeks until the system cuts out with a low flow error, and then is fine again after cleaning the filters. They are trying to find the right product to protect the inside of the radiators because whatever inhibitor they have in there at the moment clearly isn't working.
@bobshopsupreme very interesting. Do you have a buffer tank or is it an open zone?
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
@editor We have a 200 litre buffer between the hydraulic station and the radiator and underfloor heating circuits. The flow rate problem was due to undersizing of the pipes between the outdoor unit and the hydraulic station. Those pipes have now been changed and it now meets the >2000l/hr nominal flow rate when the filters are clean.
Has anyone seen this problem before? Huge anticycling times
2 months ago
Heat pump done right first time? Installation in Kent.
4 months ago
5 months ago
2 years ago
ASHP Reliability Poll - Hall of Fame vs Hall of Shame?
2 years ago
Currently viewing this topic 4 guests.
- 2,790 Topics
- 65.9 K Posts
- 2,414 Online
- 7,195 Members
RE: [Update] Indevolt PowerFlex 3000: UK ENA Listing Status
Hi everyone, We’ve seen a few discussions and inqui...
By Indevolt Tech , 10 minutes ago
Yes indeed that is exactly how it sounds. Water rushing...
By bobflux , 19 minutes ago
@singlespeed I would also recommend Octopus Energy as t...
By Toodles , 1 hour ago
@singlespeed Good to hear it is all installed! We don't...
By Will H , 1 hour ago
RE: Cooling/heating with one unit
Long term, it may be more cost effective to get an A2A ...
By Rob of York , 3 hours ago
Posted by: @editor I think we should make that approa...
By Rob of York , 24 hours ago
My neighbour received an email from Anglian Water sayin...
By AndrewJ , 1 day ago
Well the military is well known for going green, isn't ...
I've ripped out over 11kw of storage and panel heaters ...
By Singlespeed , 1 day ago
RE: Safety study for plug in batteries out to tender - looks like Q3 2027 at best before legal
I think it may depend how much of the world is on fire ...
By EtchedPixels , 1 day ago
I hope it's not the same people who make the awful TV s...
I found some interesting data about the price of heat p...
By Rob of York , 2 days ago
RE: PV and battery long payback - sense check query
Thanks for all the comments. I finally got to the bott...
By DavidB , 2 days ago
just had Vaillant over to service the HP and asked abou...
By AdamK , 3 days ago
