Using ECODAN with Hive stat
I wasn't talking about stats in each room; just one, or maybe two if you have two zones. Lots of individual room stats can be a problem for the reasons you say. TRVs are OK as long as you don't turn too many down so that your ASHP is only heating one or two rooms. We have TRVs and most are on max but we turn the bedrooms down a little. Not off, just down.
Posted by: @brooster@kev-m that’s kind of what my installer says but I only have TRVs in each room and from other research I’ve done the advice seems to be to leave them on max and don’t create cold spots as that makes the pump work harder as the emitting area is artificially reduced leaving the pump to work harder to push out the same heat through a smaller available area? TRVs are clearly not as sophisticated as individual stats in each room. That said three rooms face due South and when/if the sun shines they can easily get to 23 with solar gain which kind of throws everything out of whack anyway…
One possible way to get reasonably constant temperature control throughout your home would be to site the thermostat, but no TRV, in the coldest room, and use TRV's in the other rooms to limit the temperature.
You may still get temperature variations, since for the thermostat to operate, there is a required temperature difference between switching on and switching off. Also I am not certain how accurate and repeatable TRV's may be.
It should still be possible to use TRV's with weather compensation control, just don't fit one to the heat emitter in the coldest room.
1 month ago
4 months ago
Ecodan 11.2kw Wireless thermostat drop outs
4 months ago
Mitsubishi Ecodan System Pressure Changes - An Issue or Expected ?
4 months ago
Transforming a Derbyshire Property into an Energy-Efficient Haven
5 months ago
- 2,131 Topics
- 21 Online
- 5,655 Members
Flexi-Orb Heat Pump Scheme: A Game-Changer for the UK's Heat Pump Industry
The UK’s heat pump industry has just been handed one of...
By Mars , 45 minutes ago
By Tim441 , 4 hours ago
By Toodles , 4 hours ago
By Abernyte , 4 hours ago
@carlo I have a 16kw LG Therma V. Installed 2020 so eve...
By Tim441 , 7 hours ago
By Eliuccio , 2 days ago
By Scalextrix , 2 days ago
By Scalextrix , 4 days ago
By Toodles , 4 days ago
By heat-pump-newbie , 6 days ago
By Judith , 1 week ago
By Old_Scientist , 1 week ago
By DavidAlgarve , 1 week ago
