@heacol thank you Brendon - that's helpful.
BG want a buffer tank Octopus want a volumiser.
To be fair, I didn't push back on the buffer with BG at this point because the guy who visited me was happy to run 2 heat loss assessments one with and one without cavity wall insulation which proposed a 4kw or 6kw Daikin respectively. If I go with BG I would push back on the buffer.
@derek-m So would we all, but beggars cannot be choosers 😀
Posted by: @derek-mWith regard to the bucket analogy, think of your home as a bucket with lots of pin holes covering the whole bucket, with the bucket placed inside a larger vessel containing a certain level of water that can be raised or lowered (OAT).
If the water level inside the bucket is increased (higher IAT) then water will leak through more holes (greater heat loss), if the water level inside the larger vessel is increased then less holes will be uncovered, so less water will leak (lower heat loss).
Having cavity wall insulation is like having less holes or smaller holes in that section of bucket, while having no cavity wall insulation is like having more holes or larger holes in that particular section. This is similar to having different windows with single, double or triple glazing.
If possible assess the area of wall that has cavity wall insulation and the area that does not. It should then be possible to approximate the heat loss in the cavity wall insulated section and the section without cavity wall insulation.
Other factors that may have an affect is if the missing cavity wall insulation is on a North, South, East or West facing wall, since solar gain may then become important.
I can explain in more detail if you wish.
This is such a good analogy - it has really helped me to see the problem. I didn't realise that higher inside temps meant more heat loss.
I don't know how extensive the problem is because it got discovered so randomly starting with builders inspecting wall ties on a south, south east wall. The borescope image last week and last winter's thermal camera image show a big problem on a north facing wall.
This explains why, as soon as it is windy or wet I feel colder in the house quite quickly. I'm near the sea in the sw - it's been windy and wet and even though it's 'summer' I've had the heating on frequently.
Thank you for this - it really helps me to think through tackling the assessment problem.
I have just discovered that BOTH my installer's heat loss proposals for 4 kw Daikins (based on imaginary heat loss and imaginary fully insulated walls) have specced radiators with LOWER wattage than what's already there...
What are you comparing? Watts depends on flow temperature. So a 1kW radiator at ,70C becomes a 400W radiator at 45C
Oh dear!Posted by: @luciaI have just discovered that BOTH my installer's heat loss proposals for 4 kw Daikins (based on imaginary heat loss and imaginary fully insulated walls) have specced radiators with LOWER wattage than what's already there...
Don't let them change radiator for lower wattage ones! There are experts on the forum who would like to see the full proposals. Can you upload them?
@jamespa I'm using the Delta T watts for both - proposed K22s and my existing K11s. Is that not right? 🙈
One designed for 50º flow temp the other 45º but both came up with the same 2 radiator changes. 🤔
I know there's 2 kinds of deltas - leaving/returning and I thought the other was flow temp.... am I wrong? I made a joke about learning to divide BTUs by 3.41 to one of the guys and he said yes, that's right. When I showed him the bathroom radiator I found he looked at the watts and said it was fine.
The standard output capacity of a radiator is specified at DT50, so if the IAT is 21C, the average water temperature would need to be 71C for the radiator to output the specified quantity of thermal energy.
If you look at the Screwfix website a 1200mm x 600mm Type 11 radiator has a specified output capacity of 1141W. The same size Type 22 has a specified output capacity of 2051W.
As James has pointed out the actual quantity of thermal energy that is emitted by a radiator is dependent upon the physical size, type, and the DT between the average water temperature and the room temperature.
I have attached a copy of the Radiator Heat Output Calculator in which you can vary the parameters highlighted in yellow to see the effect.
7 months ago
7 months ago
Daikin Error Code 7H05
9 months ago
9 months ago
10 months ago
- 2,136 Topics
- 15 Online
- 5,662 Members
Powerwall 3 or Myenergi or something else?
Bit of background, 4 bed house 7.35kw heat loss, gas di...
By AdamK , 7 hours ago
By DavidAlgarve , 12 hours ago
By Transparent , 12 hours ago
By Old_Scientist , 1 day ago
By robinlawrie , 2 days ago
By NJT , 2 days ago
By PatrickVito , 5 days ago
By Mars , 5 days ago
By Tim441 , 6 days ago
By JamesPa , 7 days ago
By Tim441 , 1 week ago
By Eliuccio , 1 week ago
By Scalextrix , 1 week ago
