Sizing of heat pumps
@bobbt9866, so do Freedom make their own ASHPs? I was not aware of that if they do.
@editor no they are just a supplier of them. Mine is coming from them, via an installer
We’ve published a deep dive into heat pump sizing, and we’d love to hear from you. Did your system turn out to be the right size? Does it keep your home warm when temperatures drop?
There’s a quick poll at the end of the article... please take a moment to vote and share your experience:
We have a Clivet 6.1 (12 kW). The datasheet provides output figures for OAT of 7, 2 and -7, at set water temperatures.
Is there somewhere where we can find the heating output at specific design temp (-2)/flow temps, or is it a case of querying with the manufacturers? Just wondering how installers decide the right capacity when it isn't overly clear from what I can see, even from the datasheets.
I agree it's not very helpful. Generally, the max heat output at -2C is going to be a little lower (maybe 3-5%) that the figure at -7C. That may sound counter-intuitive, but it's because of the likelihood of defrost cycles occurring at -2C, whereas the air is 'dryer' (less moisture) at -7C so less likely to encounter frosting / defrost cycles which reduce the overall amount of available heat. Anyway, the figures for 2C, -2C and -7C are not going to be a million miles apart, and if they are very close to your heat loss then you probably want to go for a larger heat pump. Most heat loss surveys are going to contain far larger variances (or errors) than the variances between manufacturers output data at 2C, -2C and -7C OATs.
@benson HI, I don't know Clivet that well but if they have the data you will be able to get it straight from the manufacturer. I though most manufactures had more than 4 sets of data around 15,7,0 and -15 operating data.
Posted by: @bensonIs there somewhere where we can find the heating output at specific design temp
You might be able to get some idea from the Midea Engineering Data manual which can be found online (and I think has been posted on this forum at some point, but I can't seem to find it now), on the basis the Clivet is as I understand it a re-badged Midea unit. Certainly the controls etc are remarkably similar. The manual I am thinking of has detailed output tables for various models including the 12kW one, you may need to do a bit of interpolation for a specific design OAT, but won't be far out.
Edit: found a link to an online copy:
see page 41 et seq
Thanks! That is most useful. I've had a look at the Midea data manual (it is the same heat pump I believe) and that does indeed provide a lot more info.
One of our outstanding queries with our installers is the size of the ASHP they installed- they calculated around 7.8kW heat loss and we have a 12kW unit. They told us that the 10kW only has a heating output of around 7kW when -2 and this is the reason why we needed the 12kW.
From what I can see from the manual, the 10kW at LWT of 45, has an output of around 8.2kW at -5 and 8.9kW at 0.
- 2,131 Topics
- 16 Online
- 5,656 Members
By Old_Scientist , 6 hours ago
By Transparent , 10 hours ago
By PatrickVito , 2 days ago
By Tim441 , 3 days ago
By Tim441 , 4 days ago
By Toodles , 4 days ago
By Abernyte , 4 days ago
By Eliuccio , 6 days ago
By Scalextrix , 6 days ago
By Mars , 7 days ago
By Mars , 1 week ago
By Scalextrix , 1 week ago
