Servicing Hitachi HP in rural Somerset
A neighbor is struggling to get someone to service his Hitachi HP. Any suggestions (we are near Wells)?
Our Mitsubishi is serviced by its original installer and I will ask them at service time if they can help.
TIA
I'd give GreenGenUK a call or email them: sales@greengenuk.com
Not sure if they do Hitachi, but a good starting point with a reputable company.
- 2,118 Topics
- 46.6 K Posts
- 107 Online
- 4,523 Members
@jamespa Hi James, I missed one essential thing with al...
By ASHP-BOBBA , 2 hours ago
By Mars , 15 hours ago
By JamesPa , 19 hours ago
By Transparent , 1 day ago
By normpang , 1 day ago
By ASHP-BOBBA , 2 days ago
By Burtis , 6 days ago
By Old_Scientist , 6 days ago
By Lucia , 7 days ago
By Ashfp , 1 week ago
By Mars , 1 week ago
