Samsung Gen6 with no external thermostat
Hi there, my son has just moved into a house which has a Samsung Gen6 heat pump installed. its a new install but not been used for a couple of years as the house was being renovated before he bought it. We had a bit of trouble getting it working as someone has lost the wireless thermostat so we had to program the Samsung controller to work without an external thermostat. We also had to switch the receiver of the wireless thermostat permanently on otherwise the system would not run the pumps to the rads. Its up and running and they have hot water and heating but setup looks extremely complicated - we are running like a conventional heating system at the moment just to keep them warm.
So I have 3 main questions -
Can they continue to run the system with the Samsung controller set to have no external thermostat and keep the receiver for the wireless thermostat constantly on (demanding heat) or do we need to re-wire and remove the wireless thermostat receiver.
Should we replace the wireless thermostat and reprogram the system for use with external thermostat?
How should the system be programmed for most efficient use - it seems a bit of a minefield - some help would be brilliant. They do have a small solar array of 6 panels.
Thanks in advance for your help.
I have a Samsung Gen6 and mine was installed with a 3rd party room thermostat, so that is what I use. I find it very convenient.
However, I know you can use it without a separate room thermostat, using the Samsung control panel, but I think for that to be genuinely useful, the control panel needs to be installed in a sensible location to read the room temp. Ours is on the front of the DHW tank in a cupboard hence the external 3rd party room thermostat. Others do run their Samsung's in the way you describe, so hopefully someone can offer advice.
This is the room thermostat I have:
https://www.ephcontrols.com/section/cp4/
If you happen to have the same wireless receiver as shown in the link above wired into your system, maybe you could buy a replacement (they are about £60) and just pair the new room thermostat with the wireless receiver - no wiring required and full functionality restored, or replace the existing wireless receiver.
I have a Gen 6 and run it very successfully using the Samsung controller. You can see my stats in the link below
as @old_scientist says. It needs to be positioned in the main living area so that it can measure the temperature there. Moving it is easy with some twin core screened cable. Many users would agree this is the best way to run it.
Running it like a conventional heating system will be expensive. It needs to be set up for weather compensation (water law in Samsungese).
first job is to check this.
Get back to me with some more details and I can talk you through it. 🙂
- 2,149 Topics
- 47.1 K Posts
- 8 Online
- 5,667 Members
@downfield unfortunately due to a low income I only loo...
By AdamK , 6 hours ago
... easier still is to find a scapegoat and blame all w...
By JamesPa , 8 hours ago
By GrahamF , 11 hours ago
By cathodeRay , 12 hours ago
I have heard of many people with a weakness for new car...
By JamesPa , 16 hours ago
By cathodeRay , 20 hours ago
By benson , 21 hours ago
By Judith , 21 hours ago
By TechnoGeek , 1 day ago
By Judith , 1 day ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 4 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 5 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 5 days ago
By Mars , 6 days ago
