@newhouse87 If the room where the bare pipes is a habitable space, then if you are content that it does not become too warm - you have your answer. Regards, Toodles.
I would suggest that you start a new thread dedicated to your system.
Please provide as much information as possible in relation to your home type and size, heat loss calculations, COP, energy usage, type of controls (thermostats, TRV's etc.) and how the heat pump is being operated.
Posted by: @eltonThe installer seems to be gaining some national notoriety. See from 22:50 onwards. https://www.bbc.co.uk/iplayer/episode/m001vnfx/rip-off-britain-series-15-40-my-house-is-a-building-site
And good Lord, I just took a look at their Trust Pilot feedback, wish I hadn't! Some quite distressed individuals.
Just seen from some posts online that this outfit - Greener Living - is apparently closing or have closed. Anyone know any more about this? "UK's number 1 heat pump installer". Judging by their feedback, not a great surprise if it turns out they've fallen... or been pushed!
Possibly both. From the sounds of things customers with installation issues are feeling left massively in the lurch & unable to contact them on their office number so there's no sense this is a name change with continuity. Greener Living seems to have gone. Whether they try to start under another name... and take responsibility for all those botched installs under any new name.. remains to be seen.
Not rating my own system but had a visit from a heat geek the other day I asked if he was coming to a new install what heat pumps would he install. He only installs 2 brands Vaillant for a single heat pump and NIBE if you need more than one. Vaillant for level of modulation and control, NIBE because their systems work best when its multiple units.
Anything else he classed as substandard as it was based on manufacturer's transferring air to air software to air to water rather than starting from the beginning hence the lack of modulation.
In saying that any of the 'other' brands would work well enough in a good design but as we all know most aren't.
@gary What factors would be used to ascertain if a system ‘works best’? Factors that come to mind that I can think of include efficiency (COP?) reliability, noise levels, size … what else please? Regards, Toodles.
It was specifically how the 2 units work together in tandem if you look at urban plumbers recent video he installs 2 NIBEs for the first time
Logically, addressing hard water issues with a water softening solution seems like common sense ie to preserve good flow rates for an ASHP system, but I’m keen to hear any views from the experts.
Moved in a few years ago, heat pump already installed. Heating bills very high and looking to optimise performance as much as possible (from browsing these forums, my system appears to show many other red flags too!)
thanks
@mjw321 welcome to the forums. Please start a new topic dedicated to your system and share some of the red flags.
Is this ASHP install OK?
1 month ago
My Journey to Finding the Best Heat Pump for My Home in France
6 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Mid terrace - ASHP Install location
1 year ago
Any installer recommendations for Samsung ASHP?
2 years ago
- 147 Online
@toodles Your use case is indeed very different to mine...
By jamespetts , 2 hours ago
By Tim441 , 3 hours ago
Hell no, October as a matter of principle. If I had my ...
By Toodles , 3 hours ago
Seems a lot of work with hit or miss results and potent...
By dgclimatecontrol , 4 hours ago
@dgclimatecontrol I have no intention of removing the...
By Morgan , 4 hours ago
By Transparent , 4 hours ago
By HCas , 7 hours ago
By jamespetts , 8 hours ago
By HCas , 1 day ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
