@iancalderbank I agree. Just bear in mind that the BUS requires MCS and MCS requires that the whole system has been designed and installed under the same contract. My personal conclusion is that BUS costs me too much (because of the imposed restrictions) so I currently plan not to bother with this grant.
@jamespa I agree with you about BUS adding cost to install contracts. which is one reason why I did what I did. (see my write up).
But, if the householder has previously upgraded a bunch of radiators, and just so happens to have been forward looking enough to make them large enough that they would pass the MCS design criteria, then , as and when they want to go for a BUS/MCS heat pump install, there's nothing to worry about surely - their MCS installer isn't going to say "I didn't design those radiators so I'm going to replace them with some new ones that are the same size" ?
@iancalderbank "But, if the householder has previously upgraded a bunch of radiators, and just so happens to have been forward looking enough to make them large enough that they would pass the MCS design criteria, then , as and when they want to go for a BUS/MCS heat pump install, there's nothing to worry about surely - their MCS installer isn't going to say "I didn't design those radiators so I'm going to replace them with some new ones that are the same size" ?
Hopefully yes. But if they fail to take into account insulation upgrades or extensions with a more modern construction, despite the fact that you tell them about them, then no.
I have had two full 2.5hr surveys done, one of which I paid for one of which was free. In both cases their final calcs were based on solid walls throughout, despite the fact that I told them where the walls had internal insulation or were, in fact, made of lightweight block. So in my experience the most likely answer is 'no'
@jamespa - off subject I know but how did you modify your post? I can't see a way to edit a post (though I'm sure there must be a way)
I’m pleased to say that the intended installer of my heat pump has fully refunded me. They kept me informed of the progress of the refund and we agreed the process which has taken less than two weeks so all credit to them (no pun intended). Not sure of my next steps though.
Sounds like a descent "installer".!
Unfortunately, I was threatened with a bill for £14000 covering the installation of a Samsung Heat Pump.
I was refused Scottish government payback "because my incompetent "installer" was STRUCK OFF by the NIC Regulator!
To protect me from an incompetent installer I was to be landed with a £14 bill!
Fortunately the Scottish Government stepped in early December asking EST Scotland to repay the initial down-payment.
Full marks to the Scottish Government and EST Scotland.......................no marks to the MCS,NIC and RECC "Charitable Regulators".
YES!, your friendly Regulator , MCS,NIC and RECC , will , when on the defensive , reluctantly admit to being a Charity!
This "Charitable" status was imposed to provide "Light Touch Regulation" !!
ian
Horrendous is the only way I can describe my experience having a Daikin heat pump installed under the Eco4 grant. Forgive my ignorance on technicalities but I'm learning fast! It's 8 months on and I sit here with it all turned off as I await a Daikin installer to fix all the issues as it seems my installer hasn't got a clue and has just given up. They were here for 3 days last week correcting the miriad of problems still left by the Eco4 installer changing pipes and trying to sort wiring problems. Issues from the outset and when I had the funding inspection he failed the system. They had to move tank to loft and rewire something. Still issues, not least waking me at 3am 2 weeks later with horrendous noise in loft and another electrical issue and a leak into the floor where a radiator had to be moved. By then it was summer but it was clear some issues with the water. They sent the Daikin registered company out to check it all, but huge issues to be put right so back they came. Then summer over and no heat! At this point clearly installer had given up so I rang Daikin and handed over to the Daikin company again 2 weeks ago. It's still not right and even they are baffled so awaiting someone from head office to come out, in the mean time left me with it running at huge cost trying to at least get me warm but had set it at 50c as the main set point but left me with no control over anything so not on room thermostat. Cost aside, which was frightening I was absolutely boiling and with days to wait for the return visit and someone from Daikin head office to come and sort wiring I looked up how to turn the main set point down (she had mentioned it over the phone) to 45 cost a bit less but still far too hot, turned it down to 40 next day and house way too hot still so lord knows what is going on. Still costing me way too much I tried the weather compensation curve but after several tweeks no heat and no clue what they have set it to I gave up and turned everything off 3 days ago as it was the weekend and no hope of the cavalry coming and the job they thought would take 2 days max has taken 2 weeks trying to find the issue. Frankly now scared it will never be right and I won't be able to afford to have any heat at all.
@joti Oh Joti! This is very bad indeed. May I suggest you go into the settings on the MMI and set to LWT and set that down to say 35 (or a little lower if still roasting) you can set the slope to -3. Then set the lower limit to 25 (it probably won’t go lower than this anyway) and the right hand point to your intended room temperature (perhaps 20?). Now set the MMI controls for Weather Compensation and allow the system to do its’ reset and syncronise. Have you a thermostat? That should improve matters until the cavalry return; you can refine it later. Regards, Toodles. (I have a Daikin EDLA0E3)
@toodles Thanks I will give that a go and see what happens. I do have a thermostat but can't use it as they set it to LWT only to see what happened with it set to 50 I presume, I don't think they were expecting me to cook. But as I'm still not sure what the problems are reluctant to change anything else. Thankfully got a bit of sun today as my conservatory gets warm all by it's self pretty quickly. I could write a book on my installation cock ups!
@joti you say you are "cooking" with an LWT of 50, in fact in your previous point you mentioned "cooking" with an LWT of 40. So just to give you a small piece of positive feedback: that does at least imply that your system is capable of heating your house, and also implies it should be able to do so with an LWT of less than 40. In which case, you should be able to arrive at a system that is efficient to run. mid 30's will give you really good efficiency - once the system is setup right. I suggest you post as much possible info as you can about your system . it's usually worth starting a new thread for the discussion of a specific system - then all manner of helpful people will try and help you work out what to do.
@iancalderbank Will do. Indeed it does anyone who says it can't heat a house eh! I also noted that it went from 23 to 19 degrees overnight after having turned it off completely at midnight. I thought that seemed pretty good considering 1950's house and currently no loft insulation (another story).
Is this ASHP install OK?
1 month ago
My Journey to Finding the Best Heat Pump for My Home in France
6 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Mid terrace - ASHP Install location
1 year ago
Any installer recommendations for Samsung ASHP?
2 years ago
- 44 Online
By JamesPa , 57 minutes ago
Yes exactly that OK. You might want to try turnin...
By JamesPa , 1 hour ago
By jamespetts , 9 hours ago
By ASHP-BOBBA , 11 hours ago
By JamesPa , 12 hours ago
By Tim441 , 15 hours ago
By Toodles , 15 hours ago
By Transparent , 16 hours ago
By HCas , 19 hours ago
By jamespetts , 20 hours ago
By GrahamF , 2 days ago
By immunity , 2 days ago
Just done your survey!
By Judith , 2 days ago
By Judith , 3 days ago
By Tasos , 3 days ago
