Performance in the ...
Performance in the current cold snap…
17 Users
28 Reactions
11.7 K Views
(@hughf)
How is everyone’s system performing in this current cold snap?
Just curious to see if everyone is happy with their comfort and running costs, given that we are now well into ‘design conditions’ for the heat loss calcs.
 Gary
(@gary)
180sqm detached house built in 2000 so insulation isn't bad but isn't great either, 8.5KW Ecodan, UHF downstairs retrofitted so little thermal mass, Rads upstairs.
Design Temp was std 50°C at -2°C.
Really managed to dial in the WC curve this winter currently set at 32°C flow at 3°C and above any lower flow temp leads to awful cycling even with everything run as a single zone.
Ecodan can't modulate down any further.
Bottom end of curve set at 45°C at -10C.
Currently, its -5°C and flow temp is running at 40°C house is steady at 21.5°C downstairs, 20°C upstairs
I don't setback overnight its just not worth it during the winter, so the heat pumps runs space heating continually apart from an hour for DHW overnight.
Yesterday being the coldest so far the heat pump used around 40kwh, the past week has been between 30-40kwh depending on OAT.
Running costs if I was on a std tariff then heating in Dec would have cost £150. Jan will probably be over £200 over the year I think it would be on a par with gas prices.
3
@hughf - it's painful. The last week:
(@hughf)
@cathoderay are you warm enough though?
We are on the backstop rate and we’re running about £70-85/week in electric at the moment.
This post was modified 2 years ago by HughF
@hughf - yes and no. Yes if I put on extra layers of clothing, no if I don't. I'm old enough to remember getting dressed in bed as a child as we had minimal heating in those days, I just view the current inconvenience as one of those things.
(@scrchngwsl)
I'm lovely and warm (22 degC +/- 0.5) but the bills are going to hurt. On track for £210 this month. Still cheaper than a modern gas boiler overall, but the very coldest past few days are individually worse than gas. What I'd give for a Passivhaus!
ASHP: Mitsubishi Ecodan 8.5kW
PV: 5.2kWp
Battery: 8.2kWh
(@hughf)
@scrchngwsl bargain…. 🤣
bontwoody
(@bontwoody)
My 5kW Samsung is running at full capacity. COP about 2.6
Posted by: @bontwoody
It is always good to see charts from correctly operating heat pump systems.
Abernyte
(@abernyte)
This past month has been cold. My weather station says the average temperature in the past 30 days is 1C.  In that period I have been averaging electricity costs of £9/day to keep 180 square metre, timber frame exposed location house at 19/20C. I do set back for 6 hours at night to 15C and recovery is within an hour if not too sub zero and two hours if minus 3/4 C.
Flow temps rarely get above 36C and large K2/3 rads just warm to touch. All in all very satisfied with 14kW Ecodan.
(@newhouse87)
Down to -6 last night. Yesterday running fixed flow@31 deg I used 29kwh for heating/dhw. Kitchen 22, othere areas 21/20. Running 9am-11pm. Very happy compared to up to 60kwh some days my first winter ,zoned with installer  settings wc.242sqm ufh.
(@hughf)
@cathoderay quite a lot of short cycling there, have you managed to put your finger on the cause?
Page 1 / 8
