Did anyone else's ASHP spend most of yesterday (Mon 21/11/22) in defrost?
The worst possible weather for an ASHP - freezing fog! (?) No sooner had the evaporator defrosted than it had frozen up again. I guess there's not much can be done about that. My CoP went through the floor and my energy consumption went through the roof. I was tempted to switch it off and light the wood burner! Location - North East England.
Lower flow temps help avoid defrosts I think!
Â
Can you run for longer at lower flow temp?
Not all day here because the fog cleared, but a slight settings error saw our unit do 5 defrosts in the morning and only achieve a COP of 3.1 for the day.
We've not been too bad with the defrost cycles yet. We've found that the worst defrosting occurs when temperatures drop to between 0-3C and there's a lot of humidity in the air. This is one of the main reasons that we favour the hybrid approach, because the HVO can take over the heating in these instances, so we avoid horrible heat pump inefficiencies and countless defrost cycles. Two Christmases ago (when our heat pump was running solo), we had two back-to-days where the pump was in perpetual defrost mode, which affected our temperatures inside the house. We shouldn't experience that this year.Â
@allyfish, yes, freezing fog definitely isn't an air source heat pump's friend as it forces your heat pump to full speed during defrost cycles. 🤣 Your strategy to use the log burners make sense to maintain good internal temperatures so when the heat pump is turned back on it's got an easier job to do.
- 410 Online
By GC61 , 54 minutes ago
By Batpred , 1 hour ago
By GoodbyeGas , 2 hours ago
By cathodeRay , 3 hours ago
By cathodeRay , 5 hours ago
By JamesPa , 15 hours ago
By Batpred , 17 hours ago
By cathodeRay , 17 hours ago
By Batpred , 18 hours ago
By DavidB , 20 hours ago
By Batpred , 21 hours ago
By JamesPa , 22 hours ago
By Batpred , 23 hours ago
