Octopus Cosy 6 installation (fan boy video)
@majordennisbloodnok Timing Dear Boy, …Timing.
I can give you some details on a few things - like survey, order process, the changes made during that process, some customisations and then the install, commissioning, support and finally the remedial work to get me happy
Yesterday my installers told me the designers have already upgraded the Cosy 6 software to offer more 'controllability' (weather compensation and so on) for those who want to go beyond plug and play. Plus, it's likely they will continue to do this, which is great.
@wreckguru Just skim read - 1 typo - Blurb = Bulb? 😁 Otherwise great - could you possibly add your kwh use since installation?
But @editor is the gaffer so he'll do a proper edit and rejig. 😉
(First time I've seen the back of a Cosy - never imagined it was flat). 🙂
Posted by: @lucia@wreckguru Just skim read - 1 typo - Blurb = Bulb? 😁 Otherwise great - could you possibly add your kwh use since installation?
Thanks, @lucia; you beat me to it.
@wreckguru thanks for sharing. I’ll give this a solid edit in the days ahead, and post on the site. Hopefully it’ll be up before the weekend.
- 2,114 Topics
- 46.4 K Posts
- 95 Online
- 3,410 Members
@chandykris I watched that video with interest too. F...
By Old_Scientist , 34 minutes ago
By thewiseoldbird , 17 hours ago
By Transparent , 1 day ago
By Prunus , 4 days ago
By Transparent , 7 days ago
By Wh0am3ye , 7 days ago
By marcinwloch69@gmail.com , 7 days ago
By TechnoGeek , 1 week ago
