Octopus Cosy 12 Heat Pump Regret: Incredibly Loud, Poor Heating & Constant Hum - Help!
There’s another thread about the Octopus 9 which has needed anti-vibration feet rather than be flat installed on a solid slab. Perhaps any outside noise would be reduced by such feet for you? The 12 must surely be noisier?
Posted by: @judithThere’s another thread about the Octopus 9 which has needed anti-vibration felt rather than be installed on a solid slab. Perhaps any outside noise would be reduced by such feet for you? The 12 must surely be noisier?
I should think so, I thought that pretty much universal practice was to install heat pumps on AV feet and I am surprised not doing so was even considered!
Recently viewed by users: trebor12345 10 minutes ago.
- 2,417 Topics
- 54.8 K Posts
- 364 Online
- 6,096 Members
RE: Sunsynk Whole House Backup Issue
I have options to do both. I'm an innovator, for whic...
By Transparent , 1 hour ago
RE: Running my new Nibe ASHP efficiently
I didn't. I spent a while manually messing around with ...
By jamieheatpumpnew , 1 hour ago
Hi, I think I’m having some issues with my Ecodan as...
By Patch321 , 1 hour ago
RE: I’m glad the cold spell is over!
I comparison with the 65kWh used above yesterday was on...
By Judith , 1 hour ago
Hi, looking for help and advice as my installer is usel...
By LostandConfused , 1 hour ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
@synthbuilder Further to the above…‘What a difference t...
By Toodles , 2 hours ago
I should think so, I thought that pretty much universal...
By JamesPa , 2 hours ago
I'm also inclined to look into how a defrost is actuall...
By cathodeRay , 2 hours ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 13 hours ago
@robs Quick response while I'm in stationary traffic le...
By Sheriff Fatman , 13 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
@jamespa I wasn’t offended at all. You are very knowled...
By Davesoa , 14 hours ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 14 hours ago
RE: Post-Traumatic Heat Pump Stress Disorder
Yes bang on and maybe I can illustrate that by way of e...
By iotum , 16 hours ago
RE: Replacing my 18 month old Hitachi Yutaki ASHP
A big thank you to @jamespa for all his efforts online ...
By trebor12345 , 19 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor It is indeed for servicing. My current service ...
By Morgan , 20 hours ago
RE: Speedcomfort radiator fans
In case it helps Andrew Kuhne on openenergy monitor has...
By JamesPa , 21 hours ago
Things have gone quiet with you @drei. Any updates?
By Mars , 24 hours ago
