No-code, plug-and-play monitoring for your heat pump
Posted by: @grantmethestrengthIf there any more sensors that are holding registers that you would like to have a switch for let me know, it is pretty easy to create. Might be worth reaching out to the creator and see if he will update the yaml. It is a cool little family project.
Thanks so much for having a look! Only slight problem is, I have no idea where to access the code for the controller, and how to change it 😆 . Is this all in home assistant somewhere?
It is in the ESPHome settings, click on the device and edit and then add the new code. then do an OTA update
Kind Regards
Si
Grant Aerona3 13kW
Sigenergy 10kW Inverter
16kW Sigenstor battery
To update an ESP device using ESPHome in Home Assistant, you have several methods depending on how your device is set up:
## Through Home Assistant UI (Easiest Method)
1. **Navigate to ESPHome Dashboard**
- Go to Settings → Add-ons → ESPHome → Open Web UI
1. **Update via the Dashboard**
- Find your device in the ESPHome dashboard
- Click the three dots menu next to your device
- Select “Install” or “Update”
- Choose “Wirelessly” if the device is already connected to your network
If your ESP device is already running ESPHome and connected to WiFi:
1. **Make your configuration changes** in the YAML file
2. Use the “Install” button in the web interface and select “Wirelessly”
Kind Regards
Si
Grant Aerona3 13kW
- 2,118 Topics
- 46.6 K Posts
- 146 Online
- 4,523 Members
@jamespa i just want it right at the end of the day, th...
By AdamK , 2 hours ago
By downfield , 6 hours ago
By Toodles , 7 hours ago
FRV valves - can you mix and match
Great video again this week @editor, I am very interest...
By Grantmethestrength , 7 hours ago
By normpang , 2 days ago
By ASHP-BOBBA , 2 days ago
By Burtis , 6 days ago
By Old_Scientist , 7 days ago
By Lucia , 1 week ago
