New Daikin 11kW Altherma 3M install - is it working as it should?
Perhaps you obtain a higher solar yield than we do with our 8.1 kWp array (21 panels in 4 separate locations on 3 roofs and in back garden but neither optimally orientated nor free of some shading) but at present, our best yield for a day in January has been 6 kWh.
Now as to the Daikin heat pump, we have an 8 kW Daikin EDLA08 monobloc without an internal heater and the system is controlled by a Homely smart controller - thus direct comparison is meaningless - nevertheless, for what it is worth, here are a few details.
December COP was 3.6 and so far January has been 2.6; we are enjoying a 24/7 comfort level of 22.5 deg. C throughout the 4 bedroomed semi detached 1930’s house with cavity wall insulation. under-floor Q-Bot insulation on ground floor (though not under the kitchen as this is solid floor) loft insulation is 300 mm. plus some boarding with old fibre glass insulation of ~ 100 mm. There are also Celotex type panels next to the roofing felt.
We are on OE’s Cosy, use 27 kWh’s of Powerwall storage and only use grid power during the 8 cheapest hours to recharge the battery. Our DHW is separate due to not having space for the MCS requirement of a mega size tank for 4 bedrooms! (We use a Sunamp Thermino for this job which can be grid or solar charged.)
Our total electricity charge for December (we do not have gas at all) was £161.82 including all those added charges to subsidise gas etc. (1,013.96 kWh.) The solar energy exported provided 32pence.! The rest of the 101.4 kWh we produced was used rather than being exported.
You have been going through some of the most expensive part of the year for heating as the minus temperatures really do ratchet up consumption on heat pumps - come March, the consumption should be much lower but I think I would be asking why the internal heater is set to come on so soon as this will be running at a COP of 1 and not helping your savings at all!
If there is anything else you wish to ask about, just say please. Regards, Toodles.
I forgot to mention: Octopus measured our heat loss at 6.5 kWh though I don’t have any written details of the other parameters as this was just what the engineers told me at the time of survey and we didn’t have them carry out the installation in the end (very long story there!).
We live in the SE of England, on the side of a hill at 60 metres ASL. with the prevailing westerly wind hitting us square on. The house is 97 sq. metres according to the EPC we had carried out for Octopus (C 72), we have since replaced the aging double glazing throughout with triple glazing and other factors including solar, battery and heat pump hadn’t taken place at time of the assessment. Regards, Toodles.
- 2,406 Topics
- 54.6 K Posts
- 373 Online
- 6,092 Members
RE: Experience - New Build / Complete New Heating System
@vincro We have a similar sized 1950's semi with a 2...
By Bash , 49 seconds ago
RE: Heat loss based on gas usage
@jamespa Thanks. The numbers posted above were jus...
By Bash , 6 minutes ago
RE: Heat pump not reaching flow temperature
I would describe this as either a fault or a configurat...
By JamesPa , 41 minutes ago
RE: I’m glad the cold spell is over!
Thanks for the update, @judith. Cold spells with heat p...
By Mars , 47 minutes ago
RE: Post-Traumatic Heat Pump Stress Disorder
@johnbroome As I say I think you probably have a fau...
By JamesPa , 1 hour ago
@batpred I started reading this thread thinking I would...
By Hook , 2 hours ago
RE: Please help with the settings ecodan
@sheriff-fatman when I increase it to number 3, the ...
By nose1972 , 2 hours ago
So far as i can see no because its NOT connected to the...
By JamesPa , 3 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
I forgot to mention: Octopus measured our heat loss at ...
By Toodles , 4 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
Thanks Mars and thank you for reaching out to so many p...
By iotum , 4 hours ago
Forum Handle: @davec Manufacturer: Peak Energy Mode...
By DaveC , 4 hours ago
Well, the guy came out, turned the heat pump to max, we...
By razz , 4 hours ago
Midea R32 setup and bizarre running with lengthy off periods?
Hi I am new to the world of ASHP and have just had a re...
By Countryman Helmsley , 5 hours ago
Given the weather has been relatively stable, the empir...
By Batpred , 5 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor That is very kind! Thank you so much.
By johnbroome , 6 hours ago
@wally Hi I am not sure how large your house is b...
By TechnoGeek , 7 hours ago
RE: Predicted Heat Loss & Needs from MCS calcs vs EPC vs actual
I've been thinking along similar lines to @tim441 from ...
By Sheriff Fatman , 8 hours ago
Thanks, @technogeek. Good to hear about the accuracy. ...
In my case it was a very specific pattern of behaviour ...
RE: Vaillant aroTherm not heating with many faults
@ashp-bobba Yeah I'll give it a go, will check filter...
By Anon67 , 8 hours ago
