How much.
Basically 1-5 yes, 6 is, based on what I currently understand about your system, a waste of time and money given that you already have a tank. Did the installer give a reason for making this suggestion?
Having said that if the price is reasonable and they are going to take some sort of responsibility, then it may be a sacrifice worth making to get the main job done.
Would you be prepared to post the quote?
I have no problem with a Thermino, I just pointed out the differences.
The best person to discuss Thermino's with would be @toodles, since he has one installed.
Hi Toodles,
I believe you have a Thermino installed ?
Is the Thermino any good?
Would you recommend your Thermino?
@derek-m Yes, I have a Sunamp Thermino eP210 and have it connected through a Myenergi Eddi for Solar or grid supply. Very pleased with the unit - anything you would like to know? Toodles.
@iantelescope Yes I would recommend it - particularly to anyone with solar PV and or bereft of sufficient space for a large DHW tank. I found the standard dimension tanks were either too large in diameter or if slim enough, too high to fit any space we had. Previously, our gas boiler provided us with DHW stored in a 99 litre tank (which we did have space for) being a 4 bedroomed house, MCS require 210 litres minimum of storage and at the time of commencing our ASHP adventure, fitting such a tank in the loft was not favoured bu the potential installers.
Our tank is approximately a quarter of the volume of a conventional DHW tank and does not have a plethora of pipes attached all over the thing. Cold feed in and hot feed out to the tempering valve is all that is required. The Sunamp provides the Eddi with whatever commands are required so there is just mains and control cable to the Eddi. It is very well insulated too, very little energy is wasted (less than 0.75 kWh per day). Absolutely silent in operation and very little risk of Legionella so no need of disinfecting cycles.
I would recommend it to anyone who is prepared to pay the price (I’m very pleased I did!) There are various models availabe including version that work with a HT heat pump and others that are grid only etc. Regards, Toodles.
@jamesPa "Basically 1-5 yes, 6 is a waste of time and money given that you already have a tank."
Many thanks James , your opinion is appreciated.
Cost £5.5k
I have called the company asking if they understand the particular nature of my current set up.
The Boss/Salesman appeared stressed when asked if he understood that the current set up contained many components missed by my previous installer.
Got a Plumber!
My favorite Plumber has just reappeared and will come to see my proposed work!
Many thanks for your advice . Spot On!
Many thanks @toodles.
My current 200 L Hot water tank is far too heavy at 250 Kg and far too big for my kitchen!.
The 200 L was not , however, the Hot water tank I ordered being "discovered " by my installer at a local Plumbing store, presumably , at a knock down price.
Questions:
How do you heat the Thermino during Summer, mains or Solar ?
How do you heat the Thermino during Winter, Off peak mains ?
Posted by: @iantelescopeHow do you heat the Thermino during Summer, mains or Solar ?
Off peak electric and solar when available to both questions
@iantelescope Glad to hear you’re making some progress. Congratulations (though perhaps not auspiciously) on your dodgy heat pump installation 'case' now spanning over 50 pages with nearly 600 posts – a real marathon.
Could you please remind me, I recall you lodging a complaint with a consumer code – was it RECC or HIES?
My initial complaint was to MCS in August 2022
the complete complaint tree was passed through
MCS -> NIC 1 ->EST Scotland ->HES Scotland -> NIC 2 -> RECC 1 -> Consumer Arbitration CA -> RECC 2 -> NIC 3 Feb 2024)
As you say a marathon!
I have , finally, abandoned the official channels when the NIC finally said that "Nothing can be done"............now relying on an excellent Plumber.
Hopefully I will have the Heat Pump working, affordable and stable!
Posted by: @iantelescope@jamesPa "Basically 1-5 yes, 6 is a waste of time and money given that you already have a tank."
Cost £5.5k
Got a Plumber!
Posted by: @iantelescopeMy current 200 L Hot water tank is far too heavy at 250 Kg and far too big for my kitchen!.
Does weight matter? If it does check the weight of the thermio as they are preet heavy too. If the tank is too big then a thermio will solve the problem, as would a smaller tank if you don't need so much water. If you go for an electric only one you should first strictly check the conditions of any grant you received for your ashp as it might require you to continue using the ashp to heat dhw for a specified period. Just saying, I doubt if anyone will check!
With the reservation that the thermio will be half of the total and seems unnecessary (but perhaps not if size matters) then 5.5k doesn't sound too bad.
Good luck with your plumber. Probably a better bet if he/she will play.
- 1,340 Online
@editor my issue is that your poll doesn't say : "Fla...
By Gmuzz , 2 minutes ago
Homely setup on daikin heat pump
Morning I've purchased a homely hub and really could ...
By CraigH , 2 hours ago
@trebor12345 It's not marked if it is the required c ...
By Batpred , 8 hours ago
As I said I cannot access the installer portal, but my ...
By Odd_Lion , 8 hours ago
RE: Advice on potential HW Cylinder size
I think the comment about heating from cold is quicker ...
By sjcsystems , 9 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
Hi You can get a stethoscope for less than 10€ on Ama...
By bobflux , 9 hours ago
Greetings, I'm from the southeast of France. I am ren...
@editor Hi Mars Just reading the ultimate heatpump...
By Travellingwave , 12 hours ago
@tasos as above the pump is always running... Thanks ...
By benson , 12 hours ago
Still on the agile costs.. Distribution costs in Y...
By Batpred , 12 hours ago
Your DT is to low, you do not have enough heat exchange...
By ASHP-BOBBA , 12 hours ago
I am aware. But is your chart direct from a Pace BMS ap...
RE: Call for heat on open loop weather comp system
I don't know Grant system but most ASHP are very simila...
@painter26 — good idea. Please do let us know what he s...
By cathodeRay , 13 hours ago
@robs — thank you for your as ever valuable comments. T...
By cathodeRay , 15 hours ago
RE: Our Experience installing a heat pump into a Grade 2 Listed stone house
I beg to differ. I really could not make any useful pre...
Yes, but I need to reopen the battery box.. I just noti...
By Batpred , 18 hours ago
RE: The Hidden Secret to a Successful Heat Pump: Pipe Size Matters
If your heat loss is only 4kW and the pipes leaving the...
By JamesPa , 22 hours ago
My 2 bed mid-terrace definitely dropped consistently af...
By RadWhisperer , 1 day ago
With complete radio silence from Peak and no sign of th...
By DaveC , 2 days ago
No you arent, because you dont need any, and furthermor...
As I mentioned earlier most radiators have a power outp...
By Batpred , 4 days ago
