My ASHP is not performing as well as I’d hoped: COP just over 2
@hcas - exactly so. I did read one other persons similar experience but the overshoot was lower if I recall correctly. I can only make this comparison because I have an electric meter just on the cable for the heat pump, but as it is not close the FTC unit I cannot connect an output from it to the FTC which would then replace the unit's own guesstimate with the metered value. This is what most people who have invested in metering will have done.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
Have been incommunicado for a while. Now back online and will revisit this thread asap.
@toodles No. But I wasn't forced there either and The King had nothing to do with my trip LOL.
Just when I returned I had no internet which has now been resolved.
- 22 Forums
- 2,084 Topics
- 46 K Posts
- 27 Online
- 3,378 Members
A couple of pics. One shows temperature of water in tan...
By m1kegibson , 14 minutes ago
By JamesPa , 23 minutes ago
By JamesPa , 8 hours ago
There's one radiator not within the delivery, but this ...
By Sheriff Fatman , 10 hours ago
By Transparent , 1 day ago
By abam48 , 2 days ago
By ASHP-BOBBA , 2 days ago
By benson , 2 days ago
By Bart , 5 days ago
By Old_Scientist , 5 days ago
By Mars , 6 days ago
By AF1 , 6 days ago
