Should I insulate the flow and return on my rad circuit?
not sure if i should insulate the 28mm flow and return that goes to the radiator circuits. they are quite a long 8m approx. L shape run with other rads coming off them. im just worried once the water runs a further 6m or so in 22mm and 15mm there wont be much heat left.
I would as I would like the heat to be emitted in the room primarily but there is a school of thought that thinks as long as the heat is going into the house it’s not that important. Obviously if the run is in the loft then insulate.
As @bontwoody says, if they are inside the heated envelope of the house then it becomes a question of whether it is more beneficial for more of the heat to reach the radiators in question.
Another consideration for not insulating, is that with low temperature heating systems (e.g, ASHPs), we are trying to maximise the size of our emitters, and those pipes when uninsulated increase the amount of heat the system can emit into the property, so there are benefits there besides just the cost savings on the insulation. They probably act as an additional radiator in the system.
Is it possible to try running uninsulated to start with, and then add insulation later if the affected rooms are too cold? Or would adding insulation later not be possible due to pipe placement? Someone smarter than I will probably be able to calculate how much heat would be lost on your 28mm run to see if it's worthwhile insulating or if it's going to be insignificant.
I have not insulated mine because I'd rather maximise the emitter size, and I'm already struggling with a narrow dT so the more heat I can dissipate before the return flow makes it back to the heat pump, the better (e.g, it may help me go from a dT of 3C to 3.5C)
@old_scientist good point about increasing the size of the emitter!
my worry is most of the 28mm and 22mm runs are in the kitchen ceiling so quite a bit of heat is going into the corner of the house where we dont sit most of the time. there is a bedroom above one half of the kitchen, but there is some fibre glass insulation in this ceiling/floor area as was once an external roof before the bedroom was built over it, the rest is under an upstairs bathroom.
@adamk I think I would insulate as much as I could then.
this is a rough diagram of the pipe runs, beyond the 28/22mm runs it drops to 15mm to rads. for scale the Kitchen is about 5.3m x 3.2m.
- 22 Forums
- 2,004 Topics
- 43.7 K Posts
- 29 Online
- 3,166 Members
6.1kw array, South facing. West Midlands. 701kWh g...
By NJT , 3 hours ago
RE: Are Homeowners Being Silenced Over Faulty Heat Pumps?
Spot on. Last month, a homeowner booked a consultation ...
By Mars , 3 hours ago
@matthew_w It's a complex area and every case is diff...
By JamesPa , 3 hours ago
RE: Multiple simultaneous connections to Samsung R290 heat pump via Modbus
Thanks for the various replies. I've tried to summari...
By Angus , 7 hours ago
@editor Perhaps I may be a sceptic but… It rather sugge...
By Toodles , 8 hours ago
@dak51 I would also be interested. Heat pump reliab...
By JamesPa , 8 hours ago
RE: Help me keep the faith with my installation
@adamk Yes, it's a good way and an alternative to (o...
By JamesPa , 9 hours ago
RE: Frequent power outages in the Southeast – A sign of things to come?
That's a useful observation @majordennisbloodnok I'd ...
By Transparent , 13 hours ago
RE: NIBE F2040 12 kW heat pump and 100 liter buffer tank
Glad to hear that things are moving forward. The photo...
@judith Our peak is 5.4 kWp today and so far (16:35) we...
By Toodles , 1 day ago
@transparent I rather think that your LPA might refussi...
RE: Baxi Air Source Heat Pump tips and tricks
Nah, tiz them Cornish coliflour 'eads goin to announce ...
By Broadsman , 1 day ago
RE: Should I insulate the flow and return on my rad circuit?
red is 28mm orange is 22mm.
By AdamK , 1 day ago
RE: New Heat Pump - mixer shower pressure
Just note that this will yield a reduction in pressure ...
RE: Renewable Heating Hub Partners with Heat Geek
@mars as a matter of interest have you got any near Sta...
RE: help sizing rads based on room by room heat loss
I just left the old towel rail which is now way underpo...
RE: Help optimising my system!
Great progress so far, keep going you’ll get there! You...
By Judith , 2 days ago
Looking for real estate professionals for my next podcast episode
I’m hosting an episode next Friday, April 5 at 10:30 AM...
Most Active This Week
# | Name | kWhs |
1 | Mars | 277 |
2 | Majordennisbloodnok | 59 |
3 | cathodeRay | 42 |
4 | Transparent | 41 |
5 | JamesPa | 40 |
6 | Tim441 | 35 |
7 | Andris | 25 |
8 | Toodles | 25 |
9 | Terry1812 | 25 |
10 | downfield | 23 |
