I'm new to all this. Am I setting off on the right foot?
Good spot- I put kW then copied them. I suppose they amalgamated it with J/s
Thanks, both. I knew that I had to validate getting the energy to the radiators but haven't yet set about analysing it. Presently, the boiler plumbing is 28mm which splits to 22mm for the two CH and DHW valves. There is just over 2m of 22mm before splitting into two primaries, each of which supplies one 'wing' of the L-shaped property. If necessary, it would be relatively straight-forward to replace this section with 28mm when replacing the DHW cylinder. All branches from the primaries are 15mm, transitioning to 10mm for vertical drops in the walls to downstairs radiators. I am confident that there is only one radiator on each 10mm section but I need to investigate what is on each 15mm branch. There are 15 radiators in all and suspect that 12 will need replacing. The Kitchen/Diner has two tall 'Designer' radiators and I suspect that either a 3rd will need adding or the heating supplementing with an A-A heat pump, which would have the additional benefit of providing cooling in the summer months. Given the expense that all this will entail, should I consider a less efficient high temperature heat pump as an option?
- 2,152 Topics
- 47.2 K Posts
- 12 Online
- 5,671 Members
Actually they do. My case is a prime example. Catalo...
By DREI , 3 hours ago
Blunt answer? The 20-year-old gas system was f...
You can even go as low as 40c flow temp, if you want a ...
By DREI , 4 hours ago
1040kw Even beat June and July. Great month.
By Andris , 5 hours ago
I'm guessing these are the mcs defaults which are likel...
By JamesPa , 5 hours ago
Hope they know what they're doing regarding paint types...
By PatrickVito , 6 hours ago
By Toodles , 9 hours ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 15 hours ago
By Old_Scientist , 15 hours ago
@mars That response surely deserves a nomination for Tu...
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 1 day ago
When I interviewed Mitsubishi Electric at Installer ear...
@lucia One look at that protection and the rodents will...
By Toodles , 1 day ago
What is the Heat Geek Guarantee?
We regularly hear from homeowners who are researching i...
@adamk, interesting point. I’ve not focused much on Hea...
Intelligent Octopus Flux (IOF) Review
I promised @toodles that I would provide an update and ...
By Jeff , 3 days ago
