Help me keep the faith with my air source heat pump installation
UPDATE.
theyve been and sorted the flexis today by moving them so they are vertical, about the only way they could do it without moving the heat pump, so that’s sorted. Also said they will send the sparks to replace the rcd/mcb’s. So hopefully near the end of the pain, well at least until winter when I find out which rads I need to change😀.
Posted by: @adamkUPDATE.
Great news
I edited my previous post (probably after you read it) as the Vaillant manual, at least to my reading and in the version I have, actually permits the arrangement you have. However if they are going to sort it anyway that resolves the matter.
- 2,122 Topics
- 46.6 K Posts
- 54 Online
- 4,529 Members
By Toodles , 5 minutes ago
By Transparent , 2 hours ago
By Judith , 7 hours ago
By JulianC , 16 hours ago
By Judith , 21 hours ago
By JamesPa , 23 hours ago
By TRBob , 2 days ago
By normpang , 4 days ago
By ASHP-BOBBA , 5 days ago
