Help me keep the fa...
Help me keep the faith with my air source heat pump installation
18 Users
108 Reactions
20.2 K Views
(@adamk)
Got Vaillant coming on Monday. Any tips on how to get them to sort the sensors and humming sound in the house?
This post was modified 2 weeks ago by AdamK
Posted by: @adamk
Sorting the sensors - get them to swap them round or put both on the same pipe to demonstrate that they are matched, otherwise they will probably put in two new equally random sensors.  Note the mismatch and which way round they go for future reference
Humming - make sure you know what triggers it so that the conditions can be created when they are present.  Otherwise sods law guarantees there will be no humming when they come.
(@adamk)
@jamespa
They came and after a bit of push back accepted my idea to put all 4 sensors in the same place indoors and wait for them to balance. Now have 2 that are within about 100ohms of each other. Couldn’t suggest a fix for the humming other than the installer should have used Vaillant flexis. Did say the installer could move the external pipe clamps which I think might also help.
What I’ve noticed is I’ve still got the 0.2c gap which I’m guessing is the wiring resistance possibly. I’m going to cover the sensors in some insulation to see if that helps. If not I’m assuming the sensors goto the main pcb box so might measure the resistance there. Why they don’t put some small trim pots or software adjustment on these I don’t know.
I did find out today that the sensors are exactly the same as the ones used on Vaillant boilers. As that’s what he had with him. You can remove them from the boiler clip and fit them to the heat pump clips.
Posted by: @adamk
I expect they are all made in the same factory in China!
Posted by: @adamk
I suspect because the absolute value doesn't matter to the day to day operation and they don't guarantee the accuracy of energy or COP readings, which is the only thing materially dependent on them being matched!  Not entirely satisfactory I agree, it wouldn't be that difficult to calibrate them!
Posted by: @adamk
If there are no flexis then fitting them may well help.  If he has just used third party ones then less likely.  If you can find something that is vibrating in time with the hum that may give a clue of a point to either isolate or clamp!
This post was modified 2 weeks ago 2 times by JamesPa
(@adamk)
@jamespa the installer did fit primary pro flexis which aren’t that flexible. Because they had to move them as they were bending them which the manufacturer said was wrong they are being held by 3 per flexi wall clamps, I think just because those clamps were already there when it was solid pipe. So I plan to remove some so the flexis have more room to flex. Might help but not sure.
Page 26 / 26
