Heat Pump Truth or Myth#2 - Cycling uses a lot of power and ruins your COP
Posted by: @jamespaI understand that A2A heat pumps have better turndown than A2W thus sizing is less critical. I haven't seen the proof that this is true however.
I cannot state that I have noticed that our A2A heat pump can modulate to a lower output, but it can certainly respond much faster than an A2W heat pump and also may be more efficient, since it is cutting out at least one stage in the process.
- 2,118 Topics
- 46.5 K Posts
- 31 Online
- 4,522 Members
By Mars , 2 hours ago
@adamk what a shambles. Can you share some pics of the ...
By JamesPa , 6 hours ago
So the manual is correct and looks fine to me, to abbre...
By ASHP-BOBBA , 12 hours ago
By Transparent , 13 hours ago
By normpang , 14 hours ago
By ASHP-BOBBA , 1 day ago
By Toodles , 1 day ago
By Old_Scientist , 1 day ago
By Burtis , 5 days ago
By JamesPa , 5 days ago
By Old_Scientist , 6 days ago
By Lucia , 6 days ago
By Ashfp , 6 days ago
By Mars , 1 week ago
