Heat pump domestic hot water.
@david999 £2 per day just for DHW? If so, you really need to sort out your settings. It should be well under half that amount on a standard tariff. On E7 tariff yesterday at 8 degs outside we paid 28p.
You look to be paying £720 for DHW only per year, while I am paying closer to £100. 7 time less than you. Your settings need sorting out, so the immersion isn't doing any work.
- 2,114 Topics
- 46.4 K Posts
- 92 Online
- 3,410 Members
@toodles I never used smart+ with ours, so no reason re...
By benson , 39 minutes ago
By Mars , 5 hours ago
By Toodles , 21 hours ago
By Brendon Uys , 1 day ago
By Burtis , 2 days ago
By trebor12345 , 2 days ago
By Lucia , 3 days ago
By Ashfp , 3 days ago
By Mars , 5 days ago
By Mars , 7 days ago
By Prunus , 7 days ago
By Mars , 1 week ago
