Has anyone seen thi...
Has anyone seen this problem before? Huge anticycling times
5 Users
2 Reactions
(@cg360)
New Member Member
Hello, after an incredibly frustrating 18 months with a Vaillant heat pump and facing our second winter without reliable heating or hot water I stumbled across this forum!
My problem is I have a Vaillant heat pump which will not function as it should. It reports low water pressure when the pressure seems fine, continually blocks the compressor and throws up the same five faults on every occasion. The first is low water pressure, then sensor input, output etc. But the thing that puzzles me is that when the compressor is blocked (which I understand is not a 'failure'), the pump reports an anticycle time off between 65,000 and 85,000 minutes - getting on for six months! The faults are:
F703 - low pressure
F585 - sensor fault capac. outlet temp
F520 - sensor fault building circuit flow temp
F519 - sensor fault building circuit return temp
F73 - building circuit water pressure
The fault goes away if I turn off the house mains and switch it back on. But how long it will work for is another question. I've reset the mains seven times today just to heat the hot water.
I want the heat pump to work, but if even Vaillant can't get it to function properly... It's currently more work than keeping my wood stove going and far more inconvenient!
It's a Vaillant Aerotherm, feeding radiators (sized by the installers and appropriately upsized), with a solar power system feeding in during the day. That's on its own distribution board, not the same one as the pump. We have good water pressure here and there are two similar pumps running in the village using the same water supply.
I have spoken to Vaillant more times than I count. Engineers from the installers and valiant themselves have visited on more than a dozen occasions, replacing parts, fixing wiring - the same faults always recurs. The engineers are stumped. They've never seen these faults occurring.
The regional manager is coming out on Monday and I would just like to have some idea if anyone has ever seen anything similar, for whatever reason. I feel like I'm being fobbed off.
Obviously it is difficult to give a definitive answer without carrying out detailed testing, but here are a few possible ideas.
The water pressure mentioned will be the water within the heating system, which is a sealed system that should have a pressure of around 1 bar to 2 bar. It is not the mains water supply pressure.
The fact that you are getting several sensor faults together would make me suspect a circuit board problem or a data communication problem, or even something as simple as the incorrect version of firmware.
First thing to check. Do any of the data/communication cables run next to, or near to power cables? This could lead to corruption of the data signal being passed between the different units.
An 'dry joint' or bad connection on one of the circuit boards could also cause the system to fail to operate correctly. Have any of the circuit boards been swapped for known good ones to see if this cures the problem.
Has anyone checked the installed firmware version to confirm that it is correct?
(@cg360)
New Member Member
@derek-m Thank you for the answer, appreciate your time.
At various times, faults such as you describe have been suggested by the engineers. All discrete circuit boards have actually been replaced due to faults, in some cases more than once, the wiring has been replaced to eliminate the interference issue as a possibility, and several loose components have been reseated/resoldered. All sensors have been replaced too.
I think it might just be a bad unit, a lemon if you like. I haven't checked the firmware version but will make sure that is up to date. Had to restart the unit 14 times yesterday, 8 times today!
Chief engineer is here on Monday at last, so will see what he has to say. I'm intrigued by the anticycle time as I can't for the life of me think why that value would ever need to be so high. Obviously it has no upper limit imposed in the software, but some kind of input or calculation must be going awry for it to reach that number.
I'll update when the engineer has been, can't hurt to post the info in case someone else experiences a similar situation.
Thanks again!
(@dant7)
New Member Member
Hi there, I'm very curious if you got this resolved?  I have a new Vaillant Arotherm Plus that is exhibiting the exact same problem (multiple faults, very high anti-cycle time).  Did you get to the bottom of it?
@cg360 can you please provide us with an update?
(@dant7)
New Member Member
@editor In the end a Vaillant engineer came out and was a bit mystified, but replaced the main PCB in the front top right corner of the unit.  Since then the problem has not recurred so hopefully was just a defective board.
The ASHP has been working perfectly for a number of weeks now but just today failed with another issue F1117 "Compressor Phase Failure"... so back to Vaillant for assistance again!
@dant7 wow, what a pain? So I assume your heating has gone off completely on the back of this fault, correct?
(@dant7)
New Member Member
@editor Yes it is indeed out of action.  Luckily the cold weather hasn't really started yet and the engineer is booked in for Thursday so hopefully will be resolved quickly.  I did a bit of testing - the board at the back is getting power and no obvious damage.  Tech support said it could be a fuse or other failure elsewhere in the unit - the engineer will investigate.
(@cg360)
New Member Member
I’m sorry - I thought I had replied but I don’t see it!
Eventually my HP unit was replaced after the senior tech engineer came out to do a deep dive.
He could find no faults and replaced some components but to no avail. Unit failed two days later.
Have had zero problems since replacement and I would add that while we were OK with the performance of the original unit when it worked, the new one is light years ahead in speed of heating hot water and firing up the heating. So the original really wasn’t ever performing up to the expected standard. Odd to think they couldn’t figure that out, but there we go. We had nothing to compare it to because we had a combi gas system before and were expecting some compromises.
The old unit went to a local college for training purposes.
(@dant7)
New Member Member
@cg360 Hi thanks for replying - unfortunately my unit is now showing the same issue as before.  Multiple sensor faults and massive anti-cycle times.  I have a vaillant engineer coming tomorrow - is there any reference you have for your case I could refer them to?  It may lead to a speedier resolution!
If you could contact me off the forum my email is dan_tomlinson77@yahoo.co.uk
(@dant7)
New Member Member
Hi all, the issue has been resolved (fingers crossed) for me.  It took two Vaillant engineer visits - they replaced the control board on the front right of the unit on the first visit but that didn't work.  On the second visit, the engineer was a bit stumped but ended up replacing the rear power board and the entire wiring harness.  That did the trick and it has been running reliably for the last month or so!
(@jamesh)
New Member Member
Hi all, I had a 15kw installed 3 weeks ago. The past week I have started to experience the exact issue described in the first post - generally happens after a DHW run - same faults everything.
I paid full whack for the unit and so I am very unhappy. Plus it's meant to be -7C on thursday and my heating is intermitted.
I have a Vaillant engineer coming thursday (their earliest) I hope they are able to fix it.
I am based in Spain, so I have no idea if they have experience this issue here or are event interconnected enough to have heard from higher up on it.
This post was modified 4 months ago 3 times by jamesh
This post was modified 4 months ago by Mars
Page 1 / 2
