@uk_pete_2000 to be honest we are still learning so trying to find the best place for it however this is mainly redundant now as we have moved over to full WC. As I say we are just starting this journey and as a Yorkshireman I already ruing the last few decisions I have made (wincing at the smart meter every time I walked past it) but with the help of the good people on this forum we are getting there!
Regards
Si.
Kind Regards
Si
Grant Aerona3 13kW
Sigenergy 10kW Inverter
16kW Sigenstor battery
Posted by: @grantmethestrength@uk_pete_2000 to be honest we are still learning so trying to find the best place for it however this is mainly redundant now as we have moved over to full WC. As I say we are just starting this journey and as a Yorkshireman I already ruing the last few decisions I have made (wincing at the smart meter every time I walked past it) but with the help of the good people on this forum we are getting there!
Regards
Si.
Sitck with it, if you get your WC curve down to the lowest possible consistent with heating the house you should have an efficient system and plenty on here are keen to help. Also remember that high consumption now will be balanced by much lower consumption in the shoulder and low heating seasons, when you need less heat and your heat pump produces it more efficiently.
If you haven't already you may also need to 'balance' the radiators, ie adjust the lockshield valves to get either the same temperatures in all rooms or the temperature differential you want. This is a bit trial and error but pays dividends once you get it right. Its made easier by the fact that rooms are generally poorly insulated from each other, so heat gets shared anyway.
As to setbacks, the commentator above and your installer are right that a modest setback during the Cosy expensive rate and/or overnight if you wish can make sense, but ideally you need to vary the flow temperature not just turn it off. Some heat pump controllers (eg ideal, Vaillant, possibly others) are designed to do this (they 'disguise' it as changing the room temperature, even if you are operating on pure WC, to make it more user friendly. 'Under the hood' they are just changing the flow temperature). I dont know if the Grant controller can do this, either maybe another Grant owner can comment. That said just turning off for the 3 hr expensive Cosy peak probably will be OK as long as the house doesn't cool by more than a fraction of a degree.
Im personally doubtful about Cosy as a practical tarrif unless you have a battery or a very smart controller designed for tariff optimisation, like Homeley or Havenwise. After doing some analysis I went for Eon Smart Drive which gives you 7 hrs at 7p/kWh overnight, easier to manage! I do have an EV but it will still help my heat pump costs. However these things are cricitcally dependent on your personal and house circumstances.
@jamespa Thanks for the words of encouragement I dialled down the weather comp to 38c @ 0c last night and even though it was 0 outside the house never went below 21 which was too hot, so down it goes again!! The Grant does have an eco and nightime mode I am going to look into those as that seems to be the best way to modulate it.
The pump is cycling a lot but I guess it is not short cycling so that is a good thing, still burning way too much electricity! I would be interested to know how other similar Aerona3 13 kwh compare for normal jogging power draw.
Regards
Si.
Kind Regards
Si
Grant Aerona3 13kW
Posted by: @grantmethestrengthThe pump is cycling a lot but I guess it is not short cycling so that is a good thing
Is it cycling or defrost. More likely the latter at current overnight temperature
Posted by: @jamespaSome heat pump controllers (eg ideal, Vaillant, possibly others) are designed to do this (they 'disguise' it as changing the room temperature
Thank you for that, on those HP that have this facility then setback will work.
The Grant doesn't have this, but it may be included in the new controller.
Posted by: @grantmethestrengthThe Grant does have an eco and nightime mode
I just looking into those myself. From what I gather you just put a wire between the two contacts to turn it on. You could use a Grant EP001 (edit should read EP002) and a mains switch inside the house and just run a 12v wire outside, connect to each side of the terminal. Then you can turn on/off those settings when required.
Not sure if you can switch them on via modbus, without the wires.
I did find a note somewhere that one will slow it down and the other will effect the compressor by 50%, but it also seemed to indicate the the compressor may run at this setting all the time. At present my compressor runs below 40%
@grantmethestrength i had 2x10kw grant aeronas installed in 2021 and am still learning and have ongoing projects to better insulate pipe runs etc. and putting stud wall in the garage to make a plant room to improve heat loss where the cylinder and incoming pipework from the HP are.
I have WC on and have long pipe runs in a dormer so the furthest bedrooms are always on the cooler side especially my sons which has also has 3 external walls which doesn't help.
I've never got my head around why 2 HP were installed rather than a 17kw single unit but that was the installers perogative at the time. I also don't understand why the heating is switched off when heating the HW cylinder and would much rather heat the cylinder via immersion at TOU tariff overnight to give consistent heating but it was never set up that way.
@allyfish has provided invaluable resources and I have adjusted flows etc which has helped with running costs but is still hellishly expensive November to March to run only to be offset in the warmer months.
I'm hoping that when the HP (?20 year life span) do need replacing the technology then will at least half the running costs.
2 10kw Grant Aerona3
4.32 PV
Posted by: @uk_pete_2000Posted by: @jamespaSome heat pump controllers (eg ideal, Vaillant, possibly others) are designed to do this (they 'disguise' it as changing the room temperature
It's actually quite a revelation to see how Vaillant and ideal have designed the UI to WC. I suspect this because they have 20 plus years of experience of compulsory WC (for boilers) in some mainland european markets, so have worked out how to present it to the 'punter' in a way they have some chance of understanding
What they have done is actually quite simple, but goes a long way to bridging the gap between the human desire to control based on IAT, and the fact, dominated by unavoidable physics and the dynamics of control loops, that control based on OAT works better.
Posted by: @bretixI also don't understand why the heating is switched off when heating the HW cylinder and would much rather heat the cylinder via immersion at TOU tariff overnight to give consistent heating but it was never set up that way.
This is simple. Heat pumps and boilers can only supply water at one flow temperature at any one time. You need a higher ft for the dhw than you need for space heating, so it's inevitably one or the other. The only way to avoid this is to operate permanently at the much higher temp needed for dhw, which makes space heating inefficient both for boilers and heat pumps.
In the UK we have historically suffered this inefficiency for boilers, costing us for the past 20.years an additional 10% on our gas consumption as well as a reduction in comfort. Other countries with more advanced heating industries have operated in either-or mode for decades. You could still heat both dhw and space simultaneously with a heat pump, but efficiency has become more important because of rising energy prices, so the general choice is not to.
There is nothing at all to stop you turning off the dhw cycle on your heat pump and heating overnight or whenever you have cheap electricity via the immersion. It's entirely your choice.
Some where, someone said they had two HP. with this setup and some changes to the pipes, you could have one HP deal with DHW and CH and the other one just looking after the CH
Allows the best of both
Posted by: @uk_pete_2000Some where, someone said they had two HP. with this setup and some changes to the pipes, you could have one HP deal with DHW and CH and the other one just looking after the CH
You can (just like you can have two boilers) but unless you use vast amounts of dhw to the extent that the dhw is a material proportion of the total daily energy demand, there is not much point. Better just to tweak your settings to do whatever it is you want to do.
Most of the time your ashp has plenty of excess capacity assuming it's designed to cope with the standard requirements. If it is getting challenged on the coldest days because it is well matched to the demand, switch on the immersion during a cheap rate period. That will only be necessary for a handful of days per year.
Posted by: @jamespaPosted by: @uk_pete_2000Some where, someone said they had two HP. with this setup and some changes to the pipes, you could have one HP deal with DHW and CH and the other one just looking after the CH
Sorry I think you lost the point. The main question was about the CH turning off when DHW was being called for.
So having two HP, that person can have one looking after DHW & CH, while the other one just deals with CH. That way the house will always receive heat and the DHW request will not effect it.
- 2,153 Topics
- 47.3 K Posts
- 52 Online
- 5,673 Members
so which pump is running and is anything heating? &nb...
By JamesPa , 3 minutes ago
By Profzarkov , 2 hours ago
A bit of a follow up on the progress of the Ecodan pump...
By ThunderMink , 2 hours ago
By GrahamF , 3 hours ago
By cathodeRay , 4 hours ago
By ASHP-BOBBA , 14 hours ago
My Samsung Gen6 (probably same controller as yours) onl...
By Old_Scientist , 1 day ago
@rob-nezard you can see more of Drei's rad dramas here ...
By DREI , 2 days ago
Hope they know what they're doing regarding paint types...
By PatrickVito , 2 days ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 2 days ago
@mars That response surely deserves a nomination for Tu...
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 3 days ago
