@benson Ours is ‘resting’ for the summer now (unless we have a typically British summer and have to turn the heating back on!) and our DHW is solar via a Sunamp Thermino, I’m sorry, but this is no help to you I know. ☹️ Regards, Toodles.
@el_presidente yes I have the installer app. Connectivity/system check is all coming back fine.
The heat pump modbus which should show a snapshot of current parameters clearly isn’t right and is stuck to a set point a couple of days ago, so this is why the graphs are displaying as they are. Looks like one for homely support…
Actually I might try just turning it off and on again….see if that sorts it.
annoyingly we’re away for a few days so will have to fiddle with it when back later this week.
Posted by: @marct@johnmo and @benson Thanks!
I was aware there was a portal, but had never stumbled across any means to access it - when I directly requested access to it when discussing issues with Support, it is always a "no".
@benson if you login to https://account.homelyenergy.com/account/settings/dataPreferences/ you can change a toggle
Do you want to allow your installer access to your system monitoring data?
The problem with this is that it will remove one's own access to the dashboard, should you have it...
Incidentally regarding the problem above with our homely and everything being frozen and it stuck in HW mode, this was resolved by unplugging the hub for a couple of mins, and plugging it back in again...
@toodles there's little in life that's not resolved with a reboot.
Turns out this wasn’t anything to do with homely, and turning it off/on again. The problems escalated over the last day or two and turns out an external junction box and conduit entry hadn’t been installed properly. This has wiring connections for the cylinder temp sensor that were completely submerged in water that had been getting into the box. Luckily an easy fix once I’d figured it out.
@toodles exactly that. I can’t quite believe the installers did it. I assumed it might have had fully weatherproofing grommets or similar at entry points but from what I now know from researching this morning is you simply shouldn’t have cable/conduit entry points on top!
@benson Rain will always have its’ wicked way into anything that needs to be dry! The IP rating is no better than a lock when a lock picker gets to work! Philosophically yours, Toodles.
Posted by: @bensonturns out an external junction box and conduit entry hadn’t been installed properly. This has wiring connections for the cylinder temp sensor that were completely submerged in water that had been getting into the box
That's awful!
... and should've been flagged as an Alert by the software when the cylinder-temp readings no longer passed a sanity-check.
It's likely that water will have been sucked back up the wires due to capillary action.
It might cause further corrosion in time, depending on the cable composition.
I recommend you write some labels with a date, and place them at relevant points in case the corrosion causes another fault in a year or two.
"Sensor wire, water ingress 07jun25" should do it.
Place one inside that external box, and another on the cylinder next to the temp sensor.
Or alternatively, if there's sufficient spare cable to pull through, snip out 150mm each side of the junction in the box and re-make the connection.
- 37 Online
@cathoderay thanks for that. I have set up daily schedu...
By pash44pump , 18 minutes ago
So this is from Grant - can't fault them for speed of r...
By GuydeB , 33 minutes ago
I have been working on network resilience for a while. ...
By Scalextrix , 1 hour ago
Roof trusses and dry lined ceilings are a massive sound...
By AllyFish , 4 hours ago
By DREI , 14 hours ago
By JamesPa , 17 hours ago
By Cleardene-ashp , 19 hours ago
By JulianC , 20 hours ago
By NJT , 22 hours ago
By Toodles , 22 hours ago
By Transparent , 22 hours ago
By Old_Scientist , 1 day ago
By ASHP-BOBBA , 2 days ago
By Lucia , 2 days ago
By ASHP-BOBBA , 3 days ago
By Tim441 , 3 days ago
By HCas , 3 days ago
