Flow temperature & weather compensation. Impact on efficiency
Having had my heat pump for about 18 months I have gradually got to grips with understanding the controls and functions. I'm sure everyone's experience is different as it depends on so many factors including property efficiency, whether lived in all day, wfh, geographic location and more.
The most simple conclusions I came to are that the setup has best efficiency/cost with: Lowest flow temperature possible which is best managed with weather compensation. This requires a different mindset from my previous Oil central heating experiences! Target room temperatures are mostly around 21deg in main living room and kitchen but much cooler in secondary/less used rooms & bedrooms.
I came across a very useful tool that allows comparison of the impact on SCOP (Seasonal Coefficient of Performance) of different flow temperatures.
In my case using the exact model LG Therma V HM161M.U33
I can see the impact of the flow temperature and added benefit of using weather compensation. I am now using both and see that the flow temp is often as low as 30deg! But the house is reaching and holding the target 21deg without difficulty. The house is very old & generally inefficient but with underfloor heating and modern extension. At night I drop the temp just 1 degree (if more it would take a long time to warm up and/or need higher flow temp)
As can be seen in the screenshot the efficiency is around 375% at 35deg with weather compensation down to 200% at 55deg without weather compensation.
A very graphic and clear view of why flow temp should be as low as possible and weather compensation functionality should be used.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
8kw pv solar
MG4 EV
@tim441 this is really useful info and a great find. Your experience of converting from oil to ASHP mirrors mine. I'm only 3 months into the journey however. My system design temperature was 50degC but I'm finding with climatic compensation on, a maximum of 42degC flow at 0degC ambient and 30degC flow at 20degC ambient is providing efficient operation. I'm using hugely less energy than I was when I had CH and HW from kerosene, hugely less emissions, and saving around 20% on my fuel bills over the most expensive and energy intensive months. As the days draw longer and the weather warms, the ASHP efficiency and solar PV should really start to kick in and save energy.
Warm weather and heat pumps.
4 months ago
What happens when the outside temperature exceeds the upper WC point?
4 months ago
6 months ago
7 months ago
Servicing LG Therma V
1 year ago
- 2,149 Topics
- 47.1 K Posts
- 18 Online
- 5,667 Members
@downfield unfortunately due to a low income I only loo...
By AdamK , 2 hours ago
... easier still is to find a scapegoat and blame all w...
By JamesPa , 4 hours ago
By GrahamF , 7 hours ago
By cathodeRay , 8 hours ago
I have heard of many people with a weakness for new car...
By JamesPa , 12 hours ago
By cathodeRay , 16 hours ago
By benson , 17 hours ago
By Judith , 18 hours ago
By TechnoGeek , 1 day ago
By Judith , 1 day ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 3 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 4 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 5 days ago
By Mars , 5 days ago
