F.788 Building circuit pump reports internal fault - Vaillant Arotherm
I spoke to soon and thought everything was going good. Vaillant Arotherm+ 10kw installed mid Oct 2024 so 5 months old and woke up to see this error on the app F.788 Building circuit pump reports internal fault
I did try reset same error along with compressor blocked. I cleaned the magnetic filter and the other mesh filter as advised by my installer, there was a small about of build up, not terrible.
Restart and back to the same error. I have booked a Vaillant warranty visit but not happening till end of the week, just wondering if anyone else has run into this, pretty disappointed right now.
13.6kw Solar, 27kw Battery, 10kw Heat Pump and EV Car
I take it that ‘the other mesh filter’ is the ‘Y’ strainer filter? Regards, Toodles.
After bleeding and then topping up water is there anything needs bleeding?
@jeegnesh I take it that the ‘topping up’ is the opening of the two valves on the red pressure tank (until the gauge indicates ~1.5 bar, usually indicated with a red line) and then closing the two valves again? I’m not aware of anything else that needs doing after that. Regards, Toodles.
Guess I have to wait for engineer visit. I really hope they come with a pump in case it is the fault.
- 2,149 Topics
- 47.1 K Posts
- 18 Online
- 5,667 Members
@drei my career has been in Procurement so dealing with...
By Scalextrix , 6 minutes ago
@jamespa that 2011 to 2021 period was probably when "po...
By Scalextrix , 1 hour ago
I'm on Intelligent Go . Only since start of Feb. Before...
By Tim441 , 4 hours ago
@adamk apologies if my comments appeared thoughtless an...
By downfield , 5 hours ago
By GrahamF , 22 hours ago
By cathodeRay , 23 hours ago
By cathodeRay , 1 day ago
By benson , 1 day ago
By Judith , 1 day ago
By TechnoGeek , 2 days ago
By Judith , 2 days ago
I’ve looked harder now (beyond OE’s site) and it’s not ...
By HCas , 4 days ago
By Old_Scientist , 4 days ago
By DavidAlgarve , 5 days ago
By SAEnergy , 5 days ago
By Temperature_Gradient , 6 days ago
