Effects of Low Loss Header (LLH) removal - Initial findings
Small update on the findings from the data
My calcs say that the days at 1 and 2 degrees were about 25% and 20% more efficient without the LLH. However I would note these results are estimates for with the LLH as it never got that cold for the time it was installed. However the data looks fairly solid.
- 54 Online
Yeap also for heating (25-26C room temp, set water temp...
By immunity , 1 hour ago
By JamesPa , 3 hours ago
By ThunderMink , 3 hours ago
By Judith , 12 hours ago
Just done your survey!
By Judith , 13 hours ago
By JamesPa , 13 hours ago
@grahamf you appear to value your recirculating loop de...
By Judith , 14 hours ago
By Tasos , 17 hours ago
By Mars , 18 hours ago
By Scalextrix , 2 days ago
By bontwoody , 3 days ago
By Alex , 3 days ago
By GrahamF , 3 days ago
By DREI , 3 days ago
By Profzarkov , 3 days ago
