Effects of Low Loss Header (LLH) removal - Initial findings
Small update on the findings from the data
My calcs say that the days at 1 and 2 degrees were about 25% and 20% more efficient without the LLH. However I would note these results are estimates for with the LLH as it never got that cold for the time it was installed. However the data looks fairly solid.
- 2,118 Topics
- 46.6 K Posts
- 206 Online
- 4,523 Members
With their balancing process Im pretty sure all rads co...
By JamesPa , 53 minutes ago
The sad end of my ECO4 installation.
This afternoon I was advised by a charity that was help...
By Dwynwen , 3 hours ago
By dgclimatecontrol , 7 hours ago
By Transparent , 7 hours ago
By JamesPa , 11 hours ago
By TRBob , 11 hours ago
By JamesPa , 13 hours ago
By Toodles , 1 day ago
By normpang , 3 days ago
By ASHP-BOBBA , 3 days ago
