Ecodan Legionella cycle - immersion heater problem
@clockworks Along with the Law, the MCS can be an ass with absobloominglutely no margin for pragmatism; we are two and used a 99 litre DHW cylinder without ever experiencing a shortage of hot water when we needed it. MCS guidelines (and validity for the BUS grant) required us to have a 210 litre tank as minimum for our 3.5 bedroomed semi. No space for any such animal so went for the Sunamp Thermino equivalent to 210 litre system at 25% of the volume - it sits in the base of our airing cupboard. We received the £5000 grant. Regards, Toodles.
Just to close this.
Finally had the installer back last week to fit an immersion thermostat with a higher rating.
As expected, no more rapid switching, immersion stays on and water gets up to temperature.
Thanks for letting us know @clockworks
I admire your optimism that the thread is now 'closed'.
It'll get re-opened at some point...
... when someone actually contracts legionnaires disease.
There will then be a lot of finger-pointing as to which organisation should take the blame.
- 32 Online
@jamespetts If you have the space for a high capacity D...
By Toodles , 7 minutes ago
@tim441 As you say Tim, very difficult to quantify any ...
By Toodles , 15 minutes ago
@abernyte Our heating has come on twice in the last wee...
By Toodles , 28 minutes ago
James, I would not question your findings and realise t...
By Toodles , 53 minutes ago
By HCas , 2 hours ago
By jamespetts , 2 hours ago
By jamespetts , 3 hours ago
By HCas , 21 hours ago
By HCas , 22 hours ago
By GrahamF , 1 day ago
By immunity , 1 day ago
Just done your survey!
By Judith , 2 days ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
By bontwoody , 4 days ago
